    Conditional GCode Expressions
    • rabbit
      rabbit last edited by
      I would like to add a single hardware button, that load/unload filament. For that I need filament expressions,which return a boolean if filament is loaded . Eg. filament.loaded
      Is there a compilation of the expressions, which are implemented?
        @rabbit said in Conditional GCode Expressions:
        Not yet because the Object Model is still being added too. There are omre new entries coming in RRF 3.01-RC4, after that it should be more stable.
        You can explore the OM provided by your version of RRF like this:
        1. Send: M409 without parameters. This will list the top-level elements in the 'response' field.
        2. For each of those top-level elements (or just the ones you are interested in), send: M409 K"xxx" where xxx is the element. Paste the response into https://codebeautify.org/jsonviewer and click Tree Viewer to make ti easy to read and navigate.
