Left-hand axis CoreXY help!!
@perolalars said in Left-hand axis CoreXY help!!:
@dc42 Hi David So according to that page my axis moves correctly now but since I have a left-hand axis setup (yes I know I am sorry but its a lot of work making it a right-hand) and there is no solution stated if one has one " If instead it is 90 degrees clockwise, you have a left-hand axis system, which will give you mirror-image prints" what can I do to correct it? Besides rebuilding the machine that is?
Decide which axis you are going to reverse. Standard CoreXY is that looking at the front of the machine, +X is to the right and +Y is to the back.
Swap the X and Y motor connections either physically or in M584, then adjust the M569 motor directions to get X and Y moving in the right directions.
Whichever axis you reversed the direction of, reconfigure its endstop from low to high end or vice versa in M574
Whichever axis you reversed, reverse the direction of all move commands for that axis in its homing file and in homeall.g.
Ohh, thanks David, you are a savior! I was feeling a bit helpless (very much that is!) not understand what to do...
I will try this and report back... Have a good weekend! -
This post is deleted! -
@Danal Maybe I have to ask you about your config file? I cant get my head around this (in spite of David´s good description, or maybe I am to tired) so maybe I have to rebuild the end stops to looking like yours... Is it possible for you to share your homing files also? Just as info...
