    paneldue 7i only displays up to 6 extruders and 1 heated bed?
    Duet Web Control
    • tekstyle
      tekstyle last edited by
      not sure if this can be changed but if I have both the duet2wifi and duex5, will it be able to show all 7 extruders and the 1 bed? I also noticed that when I set an extruder heater port as a bed with M140 P1 H1, I don't see the second heatbed's temperature value on the paneldue display but I do see it on DWC. is that normal?
        dc42 administrators @tekstyle last edited by
        PanelDue currently assumes a fixed relationship between heaters, bed and tools. So what you observe is unfortunately normal.
        Due to constraints on display resolution, PanelDue can only display 7 heaters in total. I hope to make it more flexible than it currently is, but the limit of 7 displayed heaters will probably remain.
        • tekstyle
          Got it. Thank you!
