    Multiple tools in the Firmware Configurator
    Firmware installation
    • keyz182
      keyz182 last edited by
      Hi, not sure if this is the right place to report a bug in the firmware configurator or not (if not, anyone know where?).
      If I upload a config.json with multiple tools enabled, the configurator drops all but the first tool, so any time I alter my config, I need to remember to add the second tool manually.
      My config.json : https://gist.github.com/keyz182/9e577d89f68ddf203b0e717e4613f70a#file-config-json
      I did also test by loading up the configurator, selecting one of the presets (T3P3 Mini Kossel I think), adding a second tool, downloading the json, then loading it back up, and the second tool was missing again. So I don't believe it's an issue with my specific config.
      Thanks,
      Kieran
      • T3P3Tony
        Thanks for reporting the bug. I will ask Christian to look at this.
        Duet Hardware Designer
        www.duet3d.com
