    BLtouch don't work when printing, but when proving and mesh leveling
    • Emil
      Emil last edited by
      Hi
      I just installed a Duet WiFI with a BLTouch as Z-probe on my Creality CR-10 and it works fine when moving and extruding now, and it can do Bed Probing and mesh leveling.
      But when printing the head travels down in to the bed, so i do an emergency stop and put a paper under the head, and then raises it until it as hard pressed between as when measuring the trigger height. The distance i hade to raise it was the same as the trigger height.
      I tried some different trigger heights in the config but it doesn't change anything and it has to be raised the same height anyway.
      The trigger height is 0.92mm
      My config has these lines
      M574 X1 Y1 Z1 S1 ; Define active high microswitches
      M558 P5 X0 Y0 Z1 H10 F200 T500 ;
      G31 P10 X40 Y-25 Z0.92 ;
        How did you measure the trigger height?
        • Emil
          Emil last edited by
          @dc42:
          By this method
          https://duet3d.com/wiki/Using_mesh_bed_compensation
          But i found the problem, in homeall.g this line "G92 Z2.5" was at the end, so everytime a print started it the printer did a homeall before starting the print and set the Z-postion to wrong relative level.
          I commented away that line and after that it stops above the bed.
          Gotta get some feeler gauges to measure the height more exactly and do a better calibration though, but problem solved
          • LePaul
            LePaul last edited by
            @Emil:
            Hi
            I have ordered one of these printers based on the many, many positive reviews.
            If you can share your notes, experience and suggestions on integrating the Duet to the Creality CR-10, I would love to hear from you!
