    Error: Short-to-ground on drivers 3 4
    • matej1006
      matej1006 last edited by
      Hello today i normaly run my printer ,and then a moment when stepper start some weird sound and i check on interface and i see that problem Error: Short-to-ground on drivers 3 4. and took down heat sink and on driver 4 is small hole on driver 3 one pin with help of multimeter show that is connected to Gnd. i want to know how it's with E3D if they will swap for new or how it's whit that?
      I bought Duet2Wifi with Duex5 24.9.2019
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @matej1006 last edited by
        @matej1006 said in Error: Short-to-ground on drivers 3 4:
        a hole would suggest a somewhat acute failure, and the root cause would probably dictate terms for replacement; I'd add some pictures and whatever else could be relevant to understanding the circumstances of the event. (supply voltage, ambient temp, config file, etc)
        • matej1006
          Supply voltage is 24V ambient temp is normal around 20 25 degree config file were working normal before that last run.
          matej1006 1 Reply Last reply Reply Quote 0
          • matej1006
            matej1006 @matej1006 last edited by matej1006
            To E4 driver no visible damage
              @matej1006, I'm sorry your DueX has suffered a driver failure. I approve a warranty replacement. Please get in touch with E3D to arrange it.
              • matej1006
                Thank you @dc42
