    CR10 S5 upgrade to Duet 2 Wifi
    317
    • GT1Za
      GT1Za last edited by
      Hi Everyone,
      Im hoping I can get a bit of assistance. This is the first time Im trying to do something like this, and the first time Im trying to learn anything to do with Gcode.
      Im upgrading my CR10 S5 to the following:
      3D Fused Linear rails - this should make no difference.
      Keenovo AC heatbed with SSR - again with the SSR it shouldnt make any difference
      Hemera direct drive
      BL Touch 3.1
      (If someone has done this and would be happy to share their config and firmware files with me, Id appreciate it)
      Below please see my wiring, I think I have it done correctly, but though it was worth posting in case I hadnt.
      One this that I did change, I had the Extruder plugged into E1, I have moved this to E0.
      Things that seem to be working:
      X, Y, Z motors are driving. However I dont think Z is setup correct. If someone can confirm settings for the S5?
      The steppers are all the standard ones that came with the machine.
      Extruder (Hemera)
      Heats up fine / Cools down fine
      Fans switch on once temp is about 45 degrees.
      Forwards/Backwards works but esteps seem completely out - would appreciate assistance in getting this right?
      BL Touch wiring is as follows:
      White and black to the probe in's on the board.
      Brown wire to GPIO 1
      Red wire to GPIO 2
      Blue wire to GPIO 8
      When I power on, the BLtouch does its normal start up check by dropping the pin twice. So I believe the wiring is correct.
      When I try run G29 i get the following error:
      Absolutely lost with what to do here?
      Thanks for the assist
      NexxCat 1 Reply Last reply Reply Quote 0
      • NexxCat
        NexxCat @GT1Za last edited by NexxCat
        @GT1Za
        Sounds like you're missing the definition of the bed mesh in config.g. This is from my CR-10S, so it'll need adjusting for you:
        M557 X35:265 Y35:265 S46		; Define a 5x5 mesh grid
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
        You may also want to post your full config.g for further help 🙂
        • GT1Za
          Thanks @NexxCat. It is there but values are different. Not sure if these values are correct either though! See config.g below
          M550 P"S5 Linear" ; set printer name
          M918 P1 E4 F2000000 ; configure direct-connect display
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes backwards
          M569 P3 S0 ; physical drive 3 goes backwards
          M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X510 Y510 Z500 S0 ; set axis maxima
          M574 X1 Y1 Z1 S1 ; set active high endstops
          M307 H64 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-3 Y0 Z3 ; set Z probe trigger value, offset and trigger height
          M557 X15:495 Y15:495 S20 ; define mesh grid
          M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
          M143 H0 S150 ; set temperature limit for heater 0 to 150C
          M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
          M143 H1 S275 ; set temperature limit for heater 1 to 275C
          M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
          NexxCat Phaedrux 2 Replies Last reply Reply Quote 0
          • NexxCat
            @GT1Za
            I think your problem is your mesh definition is too aggressive. You're probing 480x480mm at 20mm increments, that's 576 points which I think is above the limit. Try changing your M557 line to this:
            M557 X15:495 Y15:495 S40 ; define mesh grid
            That's 144 points over the bed, 40mm spaced. See if it works then
            • GT1Za
              @NexxCat that worked, I took it up to S80 for a 6x6 mesh. Ill experiment later to find the right values.
              Now the if I run the Auto Bed Compensation, its starts, but the BL touch probe doesnt deploy?
              • NexxCat
                @GT1Za
                Do you have deployprobe.g and retractprobe.g files? If so, what are the contents of each? 🙂
                • GT1Za
                  @NexxCat
                  ; deployprobe.g
                  ; called to deploy a physical Z probe
                  M280 P64 S10 ; deploy BLTouch
                  ; retractprobe.g
                  ; called to retract a physical Z probe
                  M280 P64 S90 ; retract BLTouch
                  • NexxCat
                    @GT1Za
                    In config.g, change:
                    to
                    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                    and in both deployprobe.g and retractprobe.g, change the P64 to P3. Then try 🙂
                    • GT1Za
                      Nope.. Still says Z probe was not triggered during move.
                      NexxCat 2 Replies Last reply Reply Quote 0
                      • NexxCat
                        @GT1Za
                        Does it deploy now though? From the photos it looks to be wired into pin 8 of the expansion connector, which is Heater 3. Your config had it looking on Heater 64, hence the change.
                        • NexxCat
                          @GT1Za
                          Just noticed something else also. You have the original Z endstop plugged in and configured. I don't as the BLTouch does all Z homing. Try the following changes in config.g:
                          to
                          M574 X1 Y1 S1 ; set active high endstops
                          Add:
                          M574 Z1 S2                              ; Set Z endstop controlled by probe
                          • GT1Za
                            @NexxCat
                            Ill try it now. Ive always liked the idea of keeping the z stop incase the BLtouch fails. Is there no way to keep both?
                            • NexxCat
                              @GT1Za
                              I have no experience with that I'm afraid, so I can't help, but people here are really friendly and knowledgeable, so someone else may know 🙂
                              • GT1Za
                                ok, Z probe still didnt deploy when trying to home the Z. I had to hit the stop button.
                                • NexxCat
                                  @GT1Za
                                  Just to double check. The brown wire from the BLTouch is definitely plugged into Pin 8 of the expansion connector?
                                  • GT1Za
                                    definitely into pin 8
                                    • NexxCat
                                      @GT1Za
                                      DOH! I know what I missed.
                                      In both deployprobe.g and retractprobe.g, add I1 to the end of the parameters:
                                      deployprobe.g
                                      M280 P3 S10 I1
                                      retractprobe.g
                                      M280 P3 S90 I1
                                      • GT1Za
                                        GT1Za last edited by GT1Za
                                        @NexxCat
                                        I have just checked the wiring diagram:
                                        Pin 1: To Red
                                        Pin 2: To Blue/Brown
                                        Pin 8: To Orange/Yellow
                                        This is as per: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                                        This is how I have it wired
                                        I have added the I1 to both, but still not deploying
                                        NB: This is not deploying on HOMING the Z as I cant run the mesh bed before homing.
                                        • NexxCat
                                          @GT1Za
                                          Hmm, and you still have the config.g M307 set to H3?
                                          Looks like the BLTouch isn't receiving the servo signal. The "I" parameter in the deploy and retract is needed because we're wired directly into the expansion connector, if you had a Duex, it wouldn't be required, but with the correct heater configured (heater 3), and the inversion, it should work 😕
                                          Edit: Can you post your homez.g and homeall.g please?
                                          • GT1Za
                                            in the config.g:
                                            ; homeall.g
                                            ; called to home all axes
                                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 20 2020 11:57:17 GMT+0200 (South Africa Standard Time)
                                            G91 ; relative positioning
                                            G1 H1 X-515 Y-515 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                            G1 H2 X5 Y5 F6000 ; go back a few mm
                                            G1 H1 X-515 Y-515 F240 ; move slowly to X and Y axis endstops once more (second pass)
                                            G1 H1 Z-505 F240 ; move Z down stopping at the endstop
                                            G90 ; absolute positioning
                                            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                            ;G91 ; relative positioning
                                            ;G1 Z5 F100 ; lift Z relative to current position
                                            ;G90 ; absolute positioning
                                            ; homez.g
                                            ; called to home the Z axis
                                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 20 2020 11:57:18 GMT+0200 (South Africa Standard Time)
                                            G1 H1 Z-505 F3000 ; move Z down until the endstop is triggered
                                            • NexxCat
                                              @GT1Za
                                              Ok, the home macros aren't configured for a z-probe. Here are mine:
                                              ; homez.g
                                              M290 R0 S0	; Reset babystepping
                                              G1 Z5 F6000 S2  ; lift Z relative to current position
                                              G1 X118 Y148 F6000      ; go to the bed centre and home Z
                                              G30             ; home Z by probing the bed
                                              ; homeall.g
                                              G1 S1 X-305 Y-305 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                                              G1 X5 Y5 F6000          ; go back a few mm
                                              G1 S1 X-305 Y-305 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                              M98 Pdeployprobe.g      ; deploy mechanical Z probe
                                              M98 Pretractprobe.g     ; retract mechanical Z probe
                                              You'll need to adjust X and Y in both for your printer because you are 500x500.
                                              • GT1Za
                                                wow ok a whole new issue
                                                in homez.g
                                                I changed to:
                                                G1 X250 Y250 F6000 ; go to the bed centre and home Z
                                                this should be the center of the bed. but it tried to send it way off and I had to hit stop.
                                                The Y steps dont seem to be right as 150 is taking me just short of center. 250 basically made it travel off and I had to hit stop.
                                                The good news is the probe worked!
                                                • NexxCat
                                                  @GT1Za
                                                  Did you also adjust:
                                                  to
                                                  G1 S1 X-515 Y-515 F3600
                                                  and
                                                  to
                                                  • GT1Za
                                                    Yes I did.
                                                    The Y is just going too far. Everything else is as its meant to be
                                                    • NexxCat
                                                      @GT1Za
                                                      What happens if you manually home X and Y in the web UI, then use the jog controls to move them. Do they move the expected distance?
