Negative axis movements
  • So I have set it up so the printhead homes off to the side of the bed with this:
    M208 X-44 Y-18 Z0 S1 ; Set axis minima
    M208 X140 Y140 Z200 S0 ; Set axis maxima
    Is there a way to prevent manual jogging into the negative area and only allow negative to be done through homing or macros? The problem is that I forsee the IR probe PCB getting short circuited by an accidental jog into one of the bed clips.
    **EDIT ** Posted my full config files in the comment below
  • In your homing/macro file, add M208 to allow negative movements at the beginning
    then add M208 at the end to set minima to 0
  • Hmmm not sure how to effectively accomplish this. Basically before a print, I want it to home in the negative so any ooze is dropped to the bottom of the printer and if an estop, cancel, or pause is done the Z raises before moving to the negative…. But If a person is jogging the printhead and say hits the -100 they cannot jog past y-0 and x-0 at all or before raising the Z.... basically a safety feature to prevent the IR from being shorted on bed clips.
  • there are 2 different commands for movement 1 recognizes end stops other does not. sorry i am a newbie so dont remember the command but ran into this while trying to prevent - movement
  • Anyone have any ideas? Here is what I have in my configuration:
    ; config.g
    ; homeall.g
    ; called to home all axes
    G91                                          ; Relative positioning
    G1 Z5 F6000       	                 ; Lift Z by 5mm
    G1 S1 X-240 Y-240 F2000        ; Move quickly to home X and Y
    G1 X5 Y5 F600                          ; Move away from the endstops
    G1 S1 X-10 Y-10 F200 S1         ; Move slowly to home X and Y
    ; Z homing section
    G90              	                         ; Absolute positioning
    G1 X70 Y76 F6000	                 ; Put head over the centre of the bed, or wherever you want to probe
    G30             	                         ; Lower head, stop when probe triggered and set Z to trigger height
    ; Return X and Y to home area
    G1 X-40 Y-15 F6000	        ; go to X=-40 Y=-15
    ; homey.g - Optimized
    ; called to home the Y axis
    G1 Y-240 F2000 S1          	; Move quickly to Y axis endstop and stop there (first pass)
    G1 Y5 F600 		                ; Go back 5mm
    G1 Y-10 F200 S1	                ; Move slowly to Y axis endstop once more (second pass)
    G1 Z-5 F6000 		                ; Lower Z by 5mm
    ; homez.g
    ; called to home the Z axis
    G90              	                      ; Absolute mode
    ; pause.g
    ; called when a print from SD card is paused
    M83 			            ; Relative extruder moves
    G1 E-10 F3600 		    ; Retract 10mm of filament
    G1 Z50 F12000 		    ; Lift Z by 50mm
    ; stop.g
    ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
    As Jackal says: use M208 commands in the homing files to set a lower limit during homing than at other times.
  • I must have gotten overwhelmed learning all this gcode 🙂 It works Thank you
