    Ender 3 Pro and Duet wifi with BL Touch homing issues
    • Okcsmith
      Okcsmith last edited by
      I have successfully configured my ender 3 pro with duet wifi and I can communicate with board, send g code commands for bl touch and all axes, and turn on bed and heater ok. The problem comes with homing printer. After I home to hard endstops with x and y in proper physical location the x reads 0, but Y reads 235 on screen for location. Any attempt to give manual positive movement changes on y axis causes issues since it thinks it at 235 instead of 0 and won't move any further in the positive direction. I am a noobie so still figuring the g codes out. I really like the wifi interface, changing config and other files on the fly but after hours of trouble shooting I need help? The motors seem to be moving in the correct directions . I have also seen several examples of homex,y, and all files but the configurator produces only simple files.
      • OwenD
        OwenD last edited by
        You need to post your config.g at least before we can help, but at a guess I'd say you have your Y endstop configure as the high end.
        Check your M574 settings
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
          Should be: M574 X1 Y1 Z2 S1 ; Set active high endstops
          Ignore the Z2, that's for a zmax endstop
          • Okcsmith
            ; Configuration file for Duet Maestro (firmware version 2.03)
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 22 2020 13:13:28 GMT-0500 (Central Daylight Time)
            M550 P"Ender 3 Pro" ; set printer name
            ;M918 P1 E4 F2000000 ; configure direct-connect display
            M552 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P2 S1 ; physical drive 2 goes forward-
            M569 P3 S0 ; physical drive 3 goes backwards
            ;M584 X0 Y1 Z2 E3 ; set drive mapping
            M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
            M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X0 Y0 Z0 S1 ; set axis minima, CHANGED X AND Y AND Z FROM ORIGINAL
            M208 X235 Y235 Z260 S0 ; set axis maxima
            M574 X1 Y1 Z1 S1 ; set active high endstops
            M574 X1 Y2 S1 ; NEW LINE:X home to min. Y home to max. NC microswitches.
            M574 Z2 S1 ; SET ENDSTOPS CONTROLLED BY PROBE
            M307 H3 A-1 C-1 D-1 ; DISABLE HEATER ON PWM CHANNEL
            M307 H4 A-1 C-1 D-1 ; DISABLE HEATER ON PWM CHANNEL
            M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
            G31 P500 X-28 Y-8 Z2.20 ; SET Z PROBE TRIGGER VALUE,OFFSET AND TRIGGER HEIGHT-;CHANGED Z FROM 0.85 TO 0 FOR CALIBRATION
            M557 X20:205 Y40:180 S60 ; define mesh grid
            ;m557 X40:225 Y20:215 S65 ; ADDED FROM OLD ONE may be duplicate
            M305 P0 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 0
            M143 H0 S150 ; set temperature limit for heater 0 to 150C
            M305 P1 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 1
            M143 H1 S275 ; set temperature limit for heater 1 to 275C
            M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            Here is config.g file
              Phaedrux Moderator @Okcsmith last edited by
              @Okcsmith said in Ender 3 Pro and Duet wifi with BL Touch homing issues:
              Do you see the problem?
              • Okcsmith
                Yes- thanks for your quick reply- the change worked fine. I will continue with bed setup and calibration and try a test run. I figured it was something simple but still learning about G codes.
