    Duet 3 static IP
    Firmware installation
    • Marco Bona
      Marco Bona last edited by
      Is it possible to set the static IP with Duet 3?
      I tried with Putty adding in "sudo nano /etc/dhcpcd.conf"
      interface wlan0
      static ip_address = 192.168.1.40 / 24
      static routers = 192.168.1.255
      static domain_name_servers = 192.168.1.255
      but it does not allow me to perform the SBC updates.
      Is there an alternative route?
      A Former User 1 Reply Last reply Reply Quote 0
      • jens55
        jens55 last edited by
        Most setups use the DHCP server in their wireless router to achieve a static IP. You set up a reservation on the router for the mac id of the duet and anytime the duet asks for a renewed ip number it gets the same ip number assigned.
        • A Former User
          A Former User @Marco Bona last edited by
          @Marco-Bona said in Duet 3 static IP:
          Pretty sure your router and name server are wrong for a /24 network.
          Marco Bona 1 Reply Last reply Reply Quote 0
          • Marco Bona
            Marco Bona @Guest last edited by
            @bearer ,You're right, the values should be wrong, just to verify how do I recover the correct values?
            • A Former User
              A Former User last edited by
              They should be in your router, or if you revert to dhcp you can see what it provides, or even your computer should have matching settings presumably?
              Or you could try 192.168.1.1 and if that doesn't work then try 192.168.1.254 as it would be the common addresses to use.
              • Marco Bona
                @bearer ,Now it works perfectly, thanks a lot for the explanation
