    Extrusion always starts with nozzle raised 1.45mm above glass bed?
    • Merlinundefined
      Merlin
      For any print, extrusion starts with nozzle raised 1.45mm above glass bed?
      This is not caused by the print g code. I have to correct this every time with baby stepping.
      DuetWifi firmware 1.8.1 with dc42 IR sensor
      Bed levelling -Map looks good, almost all in the green
      Anyone have any ideas what might cause this?
      sample code:
      ; generated by Slic3r 1.2.9 on 2017-05-14 at 19:05:16
      M107
      G28 ; home all axes
      G1 X0 Y0 Z5 F8000 ; centre nozzle 5mm above bed
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M82 ; use absolute distances for extrusion
      G92 E0
      G1 E-6.50000 F2400.00000
      G92 E0
      G1 Z0.300 F6900.000
      G1 X0.000 Y13.676 F6900.000
      G1 E6.50000 F2400.00000
      G1 X-15.000 Y13.676 E7.28367 F1200.000
      G1 X-16.657 Y13.281 E7.37265
      G1 X-17.958 Y12.182 E7.46163
      • adavidmundefined
        adavidm
        What offset(s) do you have set in your G31 command?
        see here:
        https://duet3d.com/wiki/Setting_up_automatic_probing_of_the_print_bed
        and here:
        http://reprap.org/wiki/G-code#G31:_Set_or_Report_Current_Probe_status
        adavidm
        • Merlinundefined
          Merlin
          G31 Z0.672 P500
          I believe I'm already following all the guidelines to setting this value.
          But if, after all the calibrating and levelling, I go back and lower the nozzle until it grips the paper it then shows Z = -1.5/1.6mm instead of 0.1mm?
          • deckingmanundefined
            deckingman
            The Z value in G31 "tells" the machine how far the nozzle is away from the bed when the probe triggers. So, once you home the Z axis then do G1 Z0, the Z axis will move 0.672mm in your case and at that point, the nozzle should be just touching the bed. If the nozzle is 1.5mm above the bed, then the Z value is incorrect which means that you haven't calibrated the probe correctly. If as you say the nozzle is 1.5mm above the bed when you do G1 Z0, then you'd need to increase the Z value in G31 from 0.672 to somewhere about 2.172.
