    Cannot see COM port for duet 2 wifi
    • Cresty
      Cresty last edited by
      After changing home wifi settings i cant connect via usb to the board.
      I connect the usb cable, lights on, then if i check COM ports i cant find the right one.
      I dont know if is a driver error or something else, but i cant solve it.
      • droftarts
        droftarts administrators @Cresty last edited by
        @Cresty See this page, run through the advice, and report back if that solves it, or if anything stands out: https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        If you want/need to reinstall the Windows driver, use the DuetDriverFiles.zip file from here: https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC4
        • Cresty
          I got the problem, faulty USB cable
          • droftarts
            @Cresty Yay! Easy one!
