    M501: bad model parameters
    • jdumoulin
      jdumoulin last edited by
      I am getting "M501: bad model parameters" when I start up my duet. I read several places to put M501 to wards the end of my config which I did below. I cannot find anything online in regards to this error. Please help.
      My config below:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 26 2020 13:59:38 GMT-0400 (Eastern Daylight Time)
      M550 P"Duet 3" ; set printer name
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M584 X0.0 Y0.1 Z0.3 E0.2:0.4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E400.00:400.00 ; set steps per mm
      M566 X3000.00 Y3000.00 Z180.00 E120.00:180.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z6000.00 E30000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X300.00 Y300.00 Z50.00 E500.00:50.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E800:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X290 Y300 Z430 S0 ; set axis maxima
      M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H25 F1500 T9000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.6 ; set Z probe trigger value, offset and trigger height
      M557 X15:265 Y20:270 S50 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
      M143 H0 S60 ; set temperature limit for heater 0 to 60C
      M307 H0 B0 S0.50 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      G10 P0 X30 Y0 Z0 ; set tool 0 axis offsets
      ; Custom settings
      M584 X0.0 Y0.1 Z0.3:04 E0.2 ; set drive mapping
      M307 H0 A33.5 C106.9 D0.4 V12.2 B0 ; heated bed pid tune
      M307 H1 A340.0 C140.0 D5. V12.2 B0 ; heated bed pid tune
      M671 X-45:330 Y0:0 S10 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M501 ; Run config-override.g
      • aidar
        aidar last edited by
        @jdumoulin said in M501: bad model parameters:
        As you see, M501 runs config-override.g . So post your config-override.g here and maybe someone can help.
        • droftarts
          droftarts administrators @jdumoulin last edited by
          @jdumoulin Duet 3 with SBC? If you’ve tuned your heaters and saved with M500, it saves the heater tune M307 with empty parameters. Known bug, being fixed soon. Either that or you have no config_override.g file!
