    Duet2 + Raspberry Pi + DueUI
    DueUI
    • TopperHarley
      TopperHarley last edited by
      i have build an Hypercube Evolution based on a Duet2 mainboard. Everything works nearly perfect. Now i want to use a Raspberry Pi 4 + 7 inch touch display to control the printer. My first idea was simply to display the DWC on the display, but then i heard of the lightweight userinterface of the DueUI.
      I am not a big expert in web development, so my knowledge in JS and html is very limited...
      Can i use the Raspberry Pi with a webserver (nginx or apache) to serve DueUI? As far as i understand DSF is only supported on a Duet3 board. If this is possible i need to edit the configuration of my Duet2 board?
      Or should i use my Duet2 board in standalone mode? It is possible to serve DueUI and DWC at the same time in this case?
      Here is my setup:
      • Duet2 Wifi (converted to Ethernet) (Firmware: 2.03)
      • Rasperry Pi 4
      Thanks for your help!
      Best regards
      TopperHarley
      A Former User gtj0 2 Replies Last reply Reply Quote 0
      • A Former User
        A Former User @TopperHarley last edited by
        @TopperHarley said in Duet2 + Raspberry Pi + DueUI:
        currently that is the only option as Duet + Pi and DSF is only for the Duet 3.
        check out the wiki for that, installation section seems to suggest so.
        https://github.com/gtjoseph/DueUI/wiki
        • gtj0
          gtj0 @TopperHarley last edited by
          Absolutely. Anything that can serve files via http can be used to host DueUI including the Duet2 itself. When you connect to DueUI the first time, you'll get a setup screen that'll ask you for the IP address or hostname of the Duet2, and the location of your config file which can be on the Duet2 or the Pi.
          At the current time, that's correct.
          To run DueUI from a Pi or other webserver? No. The Duet2 doesn't know about or care about how it's controlled.
          It's totally up to you but yes, you can have both at the same time....
          http://<your_duet2> would take you to the standard DWC.
          http://<your_duet2>/dueui.html would take you to the DueUI.
          Just yell if you need help!
