    z-stop not triggering
    • Plop
      Plop last edited by
      Hi all,
      Newby here, I'm afraid. I've got a DuetWifi board for a core XY printer. The z-min stop for some reason is not triggering when I query it (x and y are fine).
      It is not the wiring or the switch as it is recognised by the software if connected to either x-min or y-min stops. Is there something wrong with the DuetWifi board? Do I need to re-map the input read by the software (i'm not using the max-endstops)? If so, how do I go about this?
      I use the 2.02 firmware version
      Thanks
      Plop
        Can you post your config.g?
        When you click the switch by hand does it trigger the Z endstop LED on the board?
        • Plop
          Plop last edited by
          Just checked. The z-stop led comes on when the trigger is pressed, just like the x and y stop leds for their respective switches.
          config.g and homez.g attached
          config.gcode
          homez.gcode
          Thanks
          Plop
            You're configured to use a Z Probe, not an endstop.
            Do you have a Z probe?
            homez
            G91              ; relative positioning
            G1 H2 Z5 F6000   ; lift Z relative to current position
            G90              ; absolute positioning
            G1 X15 Y15 F6000 ; go to first probe point
            G30              ; home Z by probing the bed
            config
            M574 X1 Y1 S0                                   ; set active low and disabled endstops
            M574 Z1 S2                                      ; set endstops controlled by probe
            M558 P1 H5 F120 T6000                           ; set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X0 Y0 Z2.5                             ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20                        ; define mesh grid
            • Plop
              Plop last edited by
              Ah - that makes sense! I do have a z-probe but I haven't got to the configuration point where that is anywhere near operational. I'll work on it. Thanks for your help! I'll learn (hopefully)
                If you need to change your config to use a Zmin endstop you'd need to make the following changes to the sections I quoted above:
                homez
                G1 H1 Z-500 F6000   ; Move Z axis to endstop
                G1 Z3 ; back off endstop
                G1 H1 Z-500 F360 ; hit endstop again slowly
                config
                M574 X1 Y1 Z1 S0                                   ; set active low and disabled endstops
                You can leave the zprobe section as is, or add a ; to comment it out.
