    Firmware update on Duet 3 via USB and BOSSA - problem
    Firmware installation
    • Mandragora
      Mandragora last edited by
      Hello, I need some help/explanations too.
      Just got myself a duet3, seller already provided SD with some files. I want to run it in standalone mode (no RPi).
      I decided to upgrade firmware via USB as on guide: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
      Steps that I've followed:
      1. Downloaded and installed BOSSA
      2. Shorted ERASE header with jumper
      3. Connected duet3 via USB to laptop (WIN 10 64bit)
      4. Windows correctly sees board: BOSSA Program Port (COM4)
      5. I wanted to download latest firmware from: https://github.com/dc42/RepRapFirmware/releases Release 3.01-RC5
      6. Here is where problems start. There are many files, and it isn't clear which is correct. I've tied to download all .bin files (Duet3Firmware_MB6HC, Duet2CombinedFirmware etc. ) When I want to use BOSSE and write I got "file does not exist"
        No idea what I am doin wrong, "send help" 🙂
      Kind regards,
      • A Former User
        @Mandragora said in Firmware update on Duet 3 via USB and BOSSA - problem:
        Duet3Firmware_MB6HC
        is the correct file. but why you get the message the file doesn't exist is a bit of a puzzle.
        The biggest question is however, why not put that file on the SD card and upgrade with M997 instead of erasing the board and resorting to the recovery procedure - did something else happen?
        edit: you could try the command line version, open a command line prompt and try
        cd Downloads
        "C:\Program Files (x86)\BOSSA\bossac.exe" -d -e -w -v -b Duet3Firmware_MB6HC.bin -R
        • Mandragora
          Thanks for your reply.
          I am not very familiar with this "software stuff" like gitlab etc. USB seemed easiest option since I don't have router around and my internet connection for computer is via Ethernet (so while connecting duet to laptop via Ethernet I don't have access to internet to look for help).
          It seems that your solution worked:
          Red DIAG LED is now flashing (1Hz)
          Now I will connect duet to laptop via Ethernet to check if I can see web interface etc.
          THX a lot for your help, I've spend 3h yesterday to figure out what was wrong.
          • Mandragora
            Ok, after successfully reinstalling firmware, I was able to connect to board with YAT via USB. After some debugging I created new configuration and web interface on new SD card - just to be sure (provided one was missing most of the files).
            And BAM, DWC is present, now I can work from here.
