    Curious problem
    • Shaun
      Shaun last edited by
      Hello All
      how to best explain....
      So recently my printer started misbehaving on homing z.
      when i hit home z it starts homing, but for some strange reason the z axis stops about 0.5 above where 0 should be. I now literally scrapped all the files on the SD card and deployed it all from scratch. Its causing me to get inconstant levels when i was homing z. I have removed the z-probe and now only have end stops (low end) configured. Printer still stopping @ what it thinks is 0 and not even triggering the end stop by about 0.5mm.
      Is there a way to clear any settings on the board and resetting it to factory defaults. I want to get the end stops working again, the probe has been problematic.
      My Config now.
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 16:00:10 GMT+0100 (British Summer Time)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z400.00 E1222.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X230 Y210 Z200 S0 ; set axis maxima
      M574 X1 Y1 Z1 S1 ; set active high endstops
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      • Danal
        Danal last edited by
        @Shaun said in Curious problem:
        No settings are kept, ever, in the base board (the WiFi module does keep SSIDs and Passwords, but that's it). Power on runs config.g and all those commands take effect at the moment they are run.
        • Danal
          Is the Z home switch at the physcial part of travel that is nearest zero? Does it click the switch before it stops?
          Also, bring up the "Machine Specific" panel and find the subpanel that shows the endstop status. Do you see correct changes when you click and unclick the z-stop switch with your finger?
          • droftarts
            droftarts Moderator @Shaun last edited by
            @Shaun Please post your homeall.g file, and the other home[axis].g files if used.
            • Shaun
              Think i resolved the problem, replaced the Z motor and seems to be working fine now. Recon its time for complete motor replacement from e3d.
              Thanks for the help guys.
