    Help with DWC layer chart
    Duet Web Control
    1.1k
    • Marco Bonaundefined
      Marco Bona @Phaedrux
      @Phaedrux , there he is:
      M117 Preparing            ;write Preparing
      G4 S2                     ;delay 2 seconds
      M140 S60                  ;set bed temperature and move on
      M141 S0                  ;set heated chamber temperature and move on
      M104 T0 S195              ;wait for the extruder to reach desired temperature
      M107                      ;start with the fan off
      G28                       ;home all axes
      T0                        ;select tool 0
      G1 X-23 Y-24 F10000       ;go to the center of bed
      G1 Z10 F1000              ;E go to Z10
      M107 P0                   ;turn off leds
      G30 X-23 Y-24 S-2 H1.915  ;probe current position and ajust Z offset
      G1 Z40 F1000              ;E go to Z40
      M106 P0 S1                ;turn on leds
      T0                        ;reset current tool
      M584 P4                   ;apply custom setting
      G1 X-137 Y160 F10000      ;go to X-137 Y160
      M117 Spray print adhesive ;write Spray print adhesive
      M226                      ;pause
      M190 S60                  ;wait for the bed to reach desired temperature
      M109 S205                 ;wait for the extruder to reach desired temperature
      G1 U130 F10000            ;go to U130
      G92 E0                    ;reset the extruder position
      G1 E25 F500               ; extrude 25mm of feed stock
      G1 E-4 F5000              ;retract 4mm
      G1 X-187 F500             ;go to X-187
      G1 Y165 F500              ;go to Y165
      G10                       ;retract
      G1 X-137 F500             ;go to X-137 and clean nozzle
      G1 XO Y0 U0 F10000        ;go to X0 Y0 U0
      M584 P3                   ;apply custom setting
      G21                       ;metric values
      G90                       ;absolute positioning
      M117 Print starting       ;write Print starting
      G1 E4 F500                ;unretract 4mm
      G11                       ;unretract
      I was considering doing operations using subprograms.
      I have to find some time to write and try them.
