    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.7k
    • Herniczundefined
      Hernicz @ChrisP
      @ChrisP I think it will be something else.
      wardialer@Wardialer-X5SA:~ $ cd /etc/apt/sources.list.d
      wardialer@Wardialer-X5SA:/etc/apt/sources.list.d $ ls
      duet3d.list  raspi.list
      wardialer@Wardialer-X5SA:/etc/apt/sources.list.d $ sudo apt-get update
      [sudo] password for wardialer:
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Ign:3 https://pkg.duet3d.com stable InRelease
      Get:4 https://pkg.duet3d.com stable Release [2,286 B]
      Get:5 https://pkg.duet3d.com stable Release.gpg [228 B]
      Fetched 2,514 B in 43s (58 B/s)
      Reading package lists... Done
      wardialer@Wardialer-X5SA:/etc/apt/sources.list.d $ sudo apt-get install duetsoftwareframework
      Building dependency tree
      Reading state information... Done
      duetsoftwareframework is already the newest version (1.2.4.0).
      0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
      Right now I'm using Raspbian with manual install (unstable skipped), but I've tried DuetPi + RC6 with same results. RC5 works well on Raspbian, haven't tried DuetPi
      As a sidenote: Please rename DuetPi to DuetOS or whatever. Cannot google it, I get results about DietPi...
      There are known knowns and known unknowns, things we know that we don't know. But there are also unknown unknowns.
      • ChrisPundefined
        ChrisP
        No, it's not something else, it because you need to be on the unstable list to be able to what you're trying. Your options are to revert your firmware back or switch to unstable.
        Tbh, your DCS version is not even recommended for RC5 you have 1.2.4.0 and 1.2.5.0 is recommended.
        Herniczundefined 1 Reply Last reply Reply Quote 0
        • Herniczundefined
          Hernicz @ChrisP
          @ChrisP Added unstable to the list update/upgraded an installed RC8.
          Now if I edit config.g save and reset then machine name reverts back to My Duet and heaters disappear from Dashboard graph.
          The only way to get these displayed properly after config edit is by unplug the whole thing and restrart.
          ChrisPundefined 1 Reply Last reply Reply Quote 0
          • ChrisPundefined
            ChrisP @Hernicz
            @Hernicz
            That's pretty interesting. I haven't update my config.g since I' update to RC8, however, at least a few of us have experienced the issue you describe since updating to RC8. We get it when the emergency stop is pressed (for eg.), but the reset after config update would likely do the same. I suggest, you add a comment on this thread, so that other methods or re-creating the issue are recorded.
            • Herniczundefined
              Hernicz @ChrisP
              @ChrisP Done
