    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.2k
    • chrishammundefined
      chrishamm administrators @Dougal1957
      @Dougal1957 The stable list is still in there: sudo rm /etc/apt/sources.list.d/duet3d.list followed by sudo apt-get update should work for you
      Duet software engineer
      • A Former User?
        A Former User @chrishamm
        @chrishamm said in RepRapFirmware 3.01-RC6 released:
        is that a problem, more importantly, should it be a problem?
        • Dougal1957undefined
          Dougal1957 @A Former User
          @bearer that sorted it Thanks very much as you probably imagine I am not good with LINUX at all although I am learning some of it
          • A Former User?
            A Former User @Dougal1957
            @Dougal1957 i only translated
            @Dougal1957 Sorry, looks like like this file was missing in the RRF package, I've just added it back and uploaded it to another location: http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin You may need to rename it to Duet3iap_spi.bin.
            into copy/paste; and we all had to learn at some point
            Dougal1957undefined 1 Reply Last reply Reply Quote 0
              @bearer Prob is that I am getting a bit old you know the saying about teaching old Dogs new tricks lol
              • A Former User?
                @Dougal1957 you're trying, and succeeding; no-one gonna fault you for that.
                • chas2706undefined
                  chas2706
                  Just upgraded and having issues.
                  On the SBC display DWC reports that the sys drive is unmounted:
                  But in web browser DWC looks ok but nothing works when clicked:
                  Any ideas?
                  • A Former User?
                    A Former User @chas2706
                    @chas2706 said in RepRapFirmware 3.01-RC6 released:
                    see what ls -l /opt/dsf/sd says in a ssh shell?
                    Danalundefined 1 Reply Last reply Reply Quote 0
                    • chas2706undefined
                      chas2706
                      @bearer said in RepRapFirmware 3.01-RC6 released:
                      ls -l /opt/dsf/sd
                      I get this:
                      pi@Duet3:~ $ ls -l /opt/dsf/sd
                      total 20
                      drwxr-xr-x 4 pi pi 4096 Mar 6 17:13 filaments
                      drwxr-xr-x 2 pi pi 4096 Apr 3 11:45 firmware
                      drwxr-xr-x 3 pi pi 4096 Apr 3 13:56 gcodes
                      drwxr-xr-x 9 pi pi 4096 Mar 17 09:08 macros
                      drwxr-xr-x 5 pi pi 4096 Apr 3 13:48 sys
                      lrwxrwxrwx 1 pi pi 7 Oct 22 12:00 www -> ../dwc2
                      pi@Duet3:~ $
                      • A Former User?
                        not sure if dcs is run as pi instead of root now, i'll leave that to someone else to confirm or correct.
                        • Danalundefined
                          Danal
                          Two errors, on a machine that started on RC4. It may be worth noting the machine was built from the Duet (full) image, and the instructions for moving to the unstable feed were followed via copy/paste. I'd be happy to report anything you guys need to see; the point of the above being it should be set up correctly.
                          Anyway, first error:
                          4/3/2020, 8:41:16 AM	M997
                          Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3iap_spi.bin
                          As suggested above, wget http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin -O opt/dsf/sd/sys/Duet3iap_spi.bin fixed this.
                          However, I then received:
                          4/3/2020, 8:42:46 AM	M997
                          Error: M997: Failed to find firmware file /opt/dsf/sd/sys/Duet3Firmware.bin
                          I tried to fix this with a symlink, this did not work. ln -s Duet3Firmware_MB6HC.bin Duet3Firmware.bin
                          lrwxrwxrwx 1 pi   pi       23 Apr  3 08:58 Duet3Firmware.bin -> Duet3Firmware_MB6HC.bin
                          I then ran sudo apt install reprapfirmware --reinstall and this did work. Including updating the main board to RC6. The symlink was still in place; this may or may not have made a difference.
                          Expansion board updates worked, and report RC5.
                          4/3/2020, 9:12:59 AM	M115 B0
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC6 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-03b3
                          4/3/2020, 9:12:55 AM	M115 B2
                          Board EXP3HC firmware 3.01-RC5 (2020-03-29b1)
                          4/3/2020, 9:12:45 AM	M115 B1
                          Board: Duet 3 MB6HC (MB6HC)
                          DSF Version: 1.3.0.0
                          Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC6 (2020-04-03b3)
                          Duet Web Control 2.1.0
                          • Danalundefined
                            Danal @A Former User
                            I had this for a few moments. An "emergency stop" restart fixed it, and/or a sudo service duetcontrolserver restart I'm not sure which.
                            • chas2706undefined
                              chas2706
                              @Danal said in RepRapFirmware 3.01-RC6 released:
                              I had this for a few moments. An "emergency stop" restart fixed it.
                              My estop doesn't work either on DWC web page or SBC display.
                              • Danalundefined
                                Danal
                                Just remembered, it may have been a sudo service duetcontrolserver restart I'm not sure which really fixed it.
                                • chas2706undefined
                                  chas2706
                                  Just applied that and now I get this on SBC display:
                                  • Danalundefined
                                    Danal
                                    It looks like something didn't upgrade, either the board or the DSF, and they won't connect. I'd try a power cycle first. Just to be sure everything that is there has an opportunity to connect.
                                    If that does not work, then I'd start re-installing things, such as:
                                    sudo apt install duetsoftwareframework --reinstall
                                    The full dependency list for DSF is:
                                    Depends: duetcontrolserver
                                    Depends: duetsd
                                    Depends: duettools
                                    Depends: duetwebserver
                                    Depends: duetwebcontrol
                                    Depends: reprapfirmware
                                    Re-Installs can't really hurt anything; if it gets beyond that, it may take @DC42 or @chrishamm to advise how to fix.
                                    • chas2706undefined
                                      chas2706
                                      I will try to re-install but not to worry if it fails because I have backup copies.
                                      Thanks for your help.
                                        jay_s_uk
                                        My duet 3 + pi updated without issue
                                        • garyd9undefined
                                          garyd9 @dc42
                                          @dc42 said in RepRapFirmware 3.01-RC6 released:
                                          The release notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
                                          ... If you were using M308 H or L parameters for thermistors attached to a Duet 3 main board, you will need to adjust those values
                                          ... The M308 thermistor H and L parameters on Duet 3 main boards have been re-scaled to match the scaling used on Duet 3 expansion and tool boards.
                                          Can you please publish the old scaling in the release notes to make it easier to adjust M308 L/H values? Even better would be a simple equation that people can just plug their old values into to get the new values.
                                          For example, I have the following M308 (with L/H values carried since using a duet2 on RRF 1.19):
                                          M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950  R4700 L54 H-97
                                          Thank you
                                          Gary
                                          "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                                          • Marco Bonaundefined
                                            Marco Bona
                                            After updating my Duet Wifi I report three problems that I am having:
                                            1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
                                            2_When I load the filament from DWC I cannot see the list of saved filaments and it seems that the tool change is being performed.
                                            3_After restarting the emergency button, the restart is not performed.
