    Printhead not moving consistently
    295
    • AdrAsundefined
      AdrAs
      I just noticed that the printhead on my delta printer is stopping/slowing down for a very short amount of time, which is causing artifacts.
      Is there a segmentation setting or something on Duet 2 mainboards to prevent that?
        What type of printer is it? On Cartesian and CoreXY printers, a common cause of movement not being smooth is that mesh bed compensation is enabled but the Z jerk limit is set too low to permit smooth movement.
        • AdrAsundefined
          AdrAs
          It's an Anycubic Predator delta printer
            Unlike almost all other firmwares, RRF doesn't use segmentation on delta printers.
            Is that a Z seam, or is it in the XY plane? It's hard to tell from the photo.
            • AdrAsundefined
              AdrAs
              I'm actually not sure. The photo is taken from the side. It really looked like the printer was stopping for a very short time to load the next instructions.
                Was it starting and stopping the layer at that point? If so then it will have stopped XY movement for a short while in order to raise Z by one layer height.
                • AdrAsundefined
                  AdrAs
                  @dc42 said in Printhead not moving consistently:
                  I have no idea, the print is currently in progress. I used Prusa Slicer. Is there any way to figure that out?
                  • AdrAsundefined
                    AdrAs
                    Looking at other places in the print it seems like a Z seam. I'll let google search figure out the solution
