    Magnetic Sensor - Extruder X reports sensor not working errors
    Filament Monitor
    1.1k
      Have all your "sensor not working" errors been accompanied by the sensor no longer flashing?
      There could indeed be a static discharge issue. Have you grounded the body of the extruder stepper motor?
      clegg78undefined 1 Reply Last reply Reply Quote 0
      • clegg78undefined
        clegg78 @dc42
        No that was the first time I've seen that happen, after unplugging and replugging it, it worked again. The Extruder body isnt grounded (its on the X Axis gantry, direct drive extruder, so no easy way to ground it. I dont have an extra wire in the bundle going to the printer right now that carries a ground consistently. I could look into running a small ground wire in the bundle to the extruders.
        And yeah upgrading to 3.1.1 fixed that stack overflow error.
        A geek designing and building his own custom IDEX printer from scratch as seen here: https://joekelly.co/3d/
        • Thaliosundefined
          Thalios
          I've been running 3.1.1 for a bit and just tonight, ran in a similar problem. I'll create a new thread with the exact issue.
          Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
          Heavily modified Ender 3 Pro (Duet 3 6HC)
          Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
          CR-10S Pro V2 (Duet 3 Mini 5+)
          and a bunch of SLA printers..
