    IDEX U endstop inverted and Min, max, InstantDv, speed, acc not set
    • Kulitorumundefined
      Kulitorum
      I am configuring a IDEX printer in firmware 1.18.1 and I cannot get endstops to work.
      My config.g:
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P5 ; Set firmware compatibility to look like Repetier
      M584 X0 Y1 Z2 E3:6 U5; Create U axis for second X carriage before we try to configure it
      ; Movement section
      M569 P0 S1  ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S1  ; Drive 1 goes forwards
      M569 P2 S1  ; Drive 2 goes forwards
      M569 P3 S0  ; Drive 3 goes forwards
      M569 P4 S1  ; Drive 4 goes forwards
      M569 P5 S0  ; Drive 5 goes forwards
      M569 P6 S0  ; Drive 5 goes forwards
      M584 X0 Y1 Z2 U5 E3:6  ; Create U axis for second X carriage before we try to configure it
      M574 X1 Y1 Z0 U2 S0  ; Set endstop configuration (X and Y endstops at low end, U endstop at high end, active high, no Z endstop)
      M906 X800 Y800 U800 Z800 E1000  ; Set motor currents (mA)
      M201 X800 Y800 U800 Z15 E1000  ; Accelerations (mm/s^2)
      M203 X15000 Y15000 U15000 Z100 E3600 ; Maximum speeds (mm/min)
      M566 X600 Y600 U600 Z30 E20  ; Maximum jerk speeds mm/minute
      M208 X200 Y200 U250 Z200  ; Set axis maxima (adjust to suit your machine)
      M208 X-50 Y0 U0 Z-0.2 S1  ; Set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
      M92 X80 Y80 U80 Z2560  ; Set axis steps/mm
      M92 E420:420  ; Set extruder steps per mm
      G90  ; Send absolute coordinates...
      M83  ; ...but relative extruder moves
      M143 S260 ; Set maximum heater temperature to 260C
      M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      M563 P0 D0 H1 ; tool 0 uses extruder drive 0 and heater 1
      M563 P1 D1 H2 ; tool 1 uses extruder drive 1 and heater 2
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M106 P0 S0 I0 F200 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F200 H2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F200 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      ; Custom settings
      M575 P1 B57600 S1 ;Setup PanelDue
      T0 ; Select first tool
      But nothing gets defined for the U axis:
      Drive Endstop hit Minimum Maximum InstantDv Max Speed Acceleration Motor Current
      0 No 0 mm 250 mm 31.67 mm/s 100 mm/s 1500 mm/s² 1200 mA
      1 Yes 0 mm 300 mm 31.67 mm/s 100 mm/s 1500 mm/s² 1200 mA
      2 No 0 mm 420 mm 0.2 mm/s 3 mm/s 250 mm/s² 1200 mA
      3 No 0 mm 350 mm 31.67 mm/s 100 mm/s 1500 mm/s² 1200 mA
      4 Yes n/a n/a 2 mm/s 20 mm/s 1250 mm/s² 1200 mA
      5 Yes n/a n/a 2 mm/s 20 mm/s 1250 mm/s² 1200 mA
      6 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 1200 mA
      7 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 1200 mA
      8 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
      9 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
      My biggest problem right now is that my 6th endstop is inverted. I checked the wiring and everything checks out - it just registers wrong.
      I think I am doing stuff in the wrong order, but I have been trying to fix it for 12 hours, so I help to find help here.
      Thank you.
        Kulitorum
        PS: When I copied the Machine properties, Endstop 1 was closed, the rest open.
          The U axis endstop switch must be connected to the E0 endstop connector. Selecting motor 5 to drive the U axis doesn't affect which switch connector is used.
            Kulitorum
            So is there a way to tell it what switch to use, or are U axies hardwired to E0?
              U axis is hard wired to E0 endstop input, and V axis to E1.
