    SPI Buffer
    spi buffer 74hc125
    • asanchezundefined
      asanchez
      Hello guys,
      I am starting work to work with the Duet3D.
      I was checking the schematic and the first question arises.
      Why the MISO signal doesn´t cross the 74HC125 buffer??
      • A Former User?
        A Former User
        Master In Slave Out; its the only signal that is driven from the slave and it is sufficient to drop the voltage over a resistor; the alternative requires a bi-directional buffer level translator.
