    Fan tacho readout
    • KP0005undefined
      KP0005
      While reading through the forums, I came to believe there is a way to connect a fan tachometer output to the Duet 2 Maestro in order to get a speed readout. I connected the pin to EXP_0 using a 1N4148 diode, cathode (black strip part) to the yellow wire, anode to Duet. Is there more to it than that? I can't seem to find the readout anywhere in the web UI.
      RRF 3.01-RC6, DWC2.11
      • A Former User?
        A Former User
        should have to configure both the fan output and input with m950
        M950 F2 C"!Fan2+exp.pb6" Q25000 ;
        see rrf3 notes for
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
        • KP0005undefined
          KP0005
          Thanks! Should I use a pullup on the input pin?
          • A Former User?
            A Former User
            i'd expect so as the tach output is usually open collector. you might have to adjust the pin name to fit the maestro as well.
            • KP0005undefined
              KP0005
              Thanks, I got the readout now! Now to just solve the little problem of it always being zero 🙂
