    Tool0 can't be deselected manualy in RRF3?!
    • Philipp.R
      Philipp.R last edited by
      i detected a issue which wont deselect Tool0 manualy.
      First off my configuration, i using:
      • Board: Duet Ethernet 1.02 or later + DueX5
      • Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC4 (2020-03-16b1)
      Let's say Tool0 is already active and i want to deselct it i typed in the DWC "T-0" to deselct Tool0, nothing happens. If i press on the "Heater1" or "T0" sign, the Tool0 will deselct and set to Standby like it should happen. So i wonder is there a difference between T-0 and pressing Heater1 or T0 in the DWC?
      Then i activated the Tool1 and typed in the DWC "T-1" the Tool1 will be deselected like it should. It seems that it only doesn't work for Tool0.
      Does anybody have a explanation for this behavior?
      • chrishamm
        chrishamm administrators last edited by
        This is expected. T-1 is a tool code with an invalid tool number, so it will deselect any tool regardless of the currently selected tool.
        Duet software engineer
          dc42 administrators @Philipp.R last edited by dc42
          @Philipp-R said in Tool0 can't be deselected manualy in RRF3?!:
          -0 and 0 are the same number, so T-0 does exactly the same as T0 does. Use T-1 to deselect whatever tool may be selected.
          • Philipp.R
            Ok so i did miss understand the concept of deselect tools.😌
            Thank you very much for the help and quick reply.
