    Upgrade to 3.0 now bed heater doesn't work
    • obscurityundefined
      obscurity
      I am in the process of trying to upgrade an adimlab printer to duet2wifi. I had the heater working then decided to upgrade the firmware and now it says "no heater found". What would cause this?
        HAve you done the necessary changes to config.g for RRF3?
        Did you get a new config file compatible with RRF3 from the online configurator?
          obscurity
          That did work. I started tjis a while ago and forgot a few of my steps
          It is now starting to heat but giving a fault about heating too slowly
            Have you done a PID tuning for the bed yet?
              obscurity
              How is that done? I didn't notice a mention of that step in the set up though i could have very easily missed it. Before the firmware upgrade it would just heat, though slowly.
                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s183
