2 hotend thermistor 80c off ?
Hello i have just installed a second hotend and the thermistor is about 80c off
This is how i looks in the config
; Thermistors
M305 P0 T100000 B4388 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 secondsthere are china thermistors
like these
https://www.aliexpress.com/item/5pcs-3d-printer-parts-100K-ohm-NTC-3950-Thermistors-with-cable-for-3D-Printer-Reprap-Mend/32488319105.html?spm=2114.13010608.0.0.2qLdqp -
Found the solution!
i hade tighten the thermistor screw to tight
losen it a bit and it reads normal
