    Object Model & Endstop Switches
    Gcode meta commands
    • dmpmassive
      dmpmassive last edited by
      Hello!
      Wondering if it's possible to check the state of an endstop switch in the object model? Not whether an axis is homed, rather the specific state of the switch regardless of homed?
      Cheers,
      David
      • OwenD
        OwenD last edited by OwenD
        use
        echo sensors[x].endstops.triggered
        where x= the number of the end stop
        ;check all end stops
        echo #sensors.endstops ^ " endstops found"
        G4 S3; wait 3 seconds
        while iterations < #sensors.endstops
        	echo "endstop-" ^ iterations ^  " Type= " ^ sensors.endstops[iterations].type ^ "state= " ^ sensors.endstops[iterations].triggered
        output (read from bottom up)
        4/8/2020, 7:53:44 PM 	endstop-2 Type= zProbeAsEndstopstate= true
        4/8/2020, 7:53:41 PM 	endstop-1 Type= inputPinstate= false
        4/8/2020, 7:53:38 PM 	endstop-0 Type= inputPinstate= true
        4/8/2020, 7:53:35 PM 	M98 P"0:/macros/conditional g code macros/check_endstops.g"
        3 endstops found
        • dmpmassive
          Lovely! Thank you!
