    Underruns during simulation
    • botundefined
      bot
      After running a simulation of a print, the M122 report shows: Underruns: 2881, 0
      When I print these files, I never typically get underruns (that I've noticed), but at high speeds I do see some hiccups.
      I assume this is merely because the simulation is going as fast as possible, and my high-resolution gcode file is overloading the system.
      Is this acceptable behaviour and does it affect simulated time?
      *not actually a robot
        dc42 administrators @bot
        Your diagnosis is correct. The simulated print time may be slightly longer than the actual print time.
