    Vision 2448 router and Duet advice
    • jzagajaundefined
      jzagaja
      Router uses 2V/5,6A stepping motors. Can I use Duet3D or should I change motors. Can I use ESTLcam for generating paths?
      • A Former User?
        A Former User
        Duet 3 is rated for 4.45A RMS which is almost 80% of your 5.6A so thats a good match. (But you may also want to check the inductance against the supply voltage to see if you get the speed you need, but if your current supply is compatible with the Duet then it should the more or less the same speed)
        ESTLcam I can't speak to.
        • jzagajaundefined
          jzagaja
          Simply measure inductance at 1kHz of one coil?
