    Macro For auto clearing print bed for hospital face shields
    • xxsteven69xxundefined
      xxsteven69xx
      I have an idea for upping my output of printing face shields for my local hospitals by using a macro to say
      Print shield.gcode
      execute move to eject parts from bed
      repeat
      If there is not repeat can I nest the macro or just copy paste the command say 10 times so I can sleep 10hrs or so.
      Example
      Mxxx Shield.gcode
      Mxx t 5mins ;cool bed
      Mxxx Shield_eject.Macro
      Mxxx ;repeat or nest this macro
      • A Former User?
        A Former User
        Using RRF3 you should be able to do a loop.
        If not look at M98 (or possibly M23+M24 if there is a reason M98 shouldn't work with the print g-code) and just copy paste the codes needed 10 times.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M98_Call_Macro_Subprogram
          xxsteven69xx
          Yeah I'm trying to write it now reading that. Is there a good way to say wait fro bed to cool to x degrees C instead of wait for heat?
          • A Former User?
            A Former User
            I don't know if M116 works both up and down; but I guess you can test it
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M116_Wait
            xxsteven69xxundefined 1 Reply Last reply Reply Quote 0
              xxsteven69xx @A Former User
              @bearer It does indeed wait for cooling
              • A Former User?
                A Former User
                Good to know! 👍
