    Duet 3 hc6 firmware '''issues''
    Firmware installation
    2.5k
      droftarts administrators @A Former User
      @Torppa said in Duet 3 hc6 firmware '''issues'':
      M584 X0.1 Y0.0 Z0.2 E0.3 ; set drive mapping
      So motor wires are connected like this?
      Y0 X1 Z2
       5  4 E3
      I've just been playing around with the networking on a standalone Duet 3. This in my config.g works for me to set a static IP address:
      M552 P192.168.0.28 S1                        ; enable network and set IP address
      M553 P255.255.255.0                          ; set netmask
      M554 P192.168.0.1                            ; set gateway
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      I can connect to the DWC, edit the IP address and reset, and the IP address will move to the new IP address.
      I can also connect when starting up without an SD card inserted. Start up, connect via USB with Serial terminal (in this case Pronterface, as I'm on a Mac):
      Connecting...
      Printer is now online.
      >>>M115
      >SENDING:M115
      >FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC4 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-03-16b1
      >>>>M552
      SENDING:M552
      Ethernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
      >>>M553 P255.255.255.0
      SENDING:M553 P255.255.255.0
      >>>M554 P192.168.0.1
      SENDING:M554 P192.168.0.1
      >>>M553
      SENDING:M553
      Net mask: 255.255.255.0
      >>>M554
      SENDING:M554
      Gateway: 192.168.0.1
      SENDING:M552 P192.168.0.28 S1
      Ethernet running, IP address = 192.168.0.28
      >>>M552
      SENDING:M552
      Ethernet is enabled, configured IP address: 192.168.0.28, actual IP address: 192.168.0.28
      >>>M552 S0
      SENDING:M552 S0
      Network stopped
      >>>M552 P192.168.0.69 S1
      SENDING:M552 P192.168.0.69 S1
      Ethernet running, IP address = 192.168.0.69
      >>>M552
      SENDING:M552
      Ethernet is enabled, configured IP address: 192.168.0.69, actual IP address: 192.168.0.69
      I can ping all the addresses I set, even when running with no SD card. I did make sure to send the subnet mask and gateway before the static IP address and enabling the network, though. This is with firmware 3.01-RC4.
      So I can't replicate the problem you are seeing.
        The fans are cooling the steppers, aiming to print mostly nylon ans ASA, duet has a fan 240v for cooling. dont knoiw if this is abit mad for my first 3d printter
        With you motor currents set like this:
        M906 X2600 Y2600 Z2600 E1197
        The Duet 3 should barely be getting warm, even without a fan. But then depends how close to other hot things it is, how confined the enclosure is, what the ambient temperature is. It's difficult to over-cool something!
        • A Former User?
          A Former User
          The enclosure is 350x350x50mm duet sits on 8mm pcb stands. has 3 went meshes, cables are running in the perimeters of the enclosure and the cable passtru holes have silicone thinggys that i salvaged from an old pc case.
          Now that i think of it i might use the old itx case as the enclosure.
          the PSU is not in the same box as the duet.
          PSU, Mean Well RSP-500-24.
          • A Former User?
            A Former User
            MCU Temperature
            29.7 C
            Ambient is 24.8 C
            Got the IP changed to a statick one last night, no idea how i did.
              @Torppa you can calibrate the CPU temperature offset with https://duet3d.dozuki.com/Wiki/Gcode#Section_M912_Set_electronics_temperature_monitor_adjustment
              • PrintMakeundefined
                PrintMake
                This post is deleted!
                • A Former User?
                  A Former User @PrintMake
