    DuetRFF Cura plugin Duet 3
    1553
    • Gio
      Gio last edited by
      hi, I use Cura 4.5 and Duet 3 updated to the latest version. "Print on ..." I get network error.
      What did I forget?
      Thanks.
      Here the Cura log (this one is with password but I get same error without):
      2020-04-10 09:40:21,096 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [72]: Ultimaker 2ET-print | New DuetRRFOutputDevice created
      2020-04-10 09:40:21,097 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [73]: Ultimaker 2ET-print | URL: http://192.168.1.110/
      2020-04-10 09:40:21,098 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [74]: Ultimaker 2ET-print | Duet password: set.
      2020-04-10 09:40:21,099 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [75]: Ultimaker 2ET-print | HTTP Basic Auth user: empty.
      2020-04-10 09:40:21,100 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [76]: Ultimaker 2ET-print | HTTP Basic Auth password: empty.
      2020-04-10 09:40:21,102 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [72]: Ultimaker 2ET-simulate | New DuetRRFOutputDevice created
      2020-04-10 09:40:21,103 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [73]: Ultimaker 2ET-simulate | URL: http://192.168.1.110/
      2020-04-10 09:40:21,103 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [74]: Ultimaker 2ET-simulate | Duet password: set.
      2020-04-10 09:40:21,104 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [75]: Ultimaker 2ET-simulate | HTTP Basic Auth user: empty.
      2020-04-10 09:40:21,105 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [76]: Ultimaker 2ET-simulate | HTTP Basic Auth password: empty.
      2020-04-10 09:40:21,106 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [72]: Ultimaker 2ET-upload | New DuetRRFOutputDevice created
      2020-04-10 09:40:21,107 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [73]: Ultimaker 2ET-upload | URL: http://192.168.1.110/
      2020-04-10 09:40:21,107 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [74]: Ultimaker 2ET-upload | Duet password: set.
      2020-04-10 09:40:21,109 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [75]: Ultimaker 2ET-upload | HTTP Basic Auth user: empty.
      2020-04-10 09:40:21,109 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.init [76]: Ultimaker 2ET-upload | HTTP Basic Auth password: empty.
      2020-04-10 09:55:04,894 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.onFilenameAccepted [160]: Ultimaker 2ET-print | Filename set to: CFFFP_PolyBox Distanziale.gcode
      2020-04-10 09:55:05,120 - DEBUG - [MainThread] LinearAdvanceSettingPlugin.LinearAdvanceSettingPlugin._filterGcode [109]: No used extruders specify a linear advance factor
      2020-04-10 09:55:05,122 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.onFilenameAccepted [173]: Ultimaker 2ET-print | Loading gcode...
      2020-04-10 09:55:05,256 - DEBUG - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice.onFilenameAccepted [184]: Ultimaker 2ET-print | Connecting...
      2020-04-10 09:55:05,292 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._processRequest [308]: Request [5e4e2928768b49589f7e5dc20c74f688] started
      2020-04-10 09:55:05,300 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [279]: No more requests to process, stop
      2020-04-10 09:55:05,511 - ERROR - [MainThread] DuetRRFPlugin.DuetRRFOutputDevice._onNetworkError [336]: _onNetworkError: 203
      • resam
        resam last edited by
        @Gio said in DuetRFF Cura plugin Duet 3:
        Is this the URL under which you can reach your printer and it shows DWC?
        I don't see anything obviously wrong here...
        • Gio
          Gio last edited by
          Thanks @resam for quick answer.
          Yes the ip is correct… I think 🙂
          • resam
            Unfortunately I do not have a Duet3 - so I never tested the Cura Plugin.
            Are you running your Duet3 stand-alone or with a SBC attached?
            • Gio
              Gio last edited by
              Duet3 with Raspberry PI3 Model B.
              Do you want me to make some tests?
              Thanks.
              • resam
                I'm wondering - does the SBC for a Duet3 actually expose the usual RRF HTTP endpoints? Are they simply passed-through to RRF?
                https://github.com/dc42/RepRapFirmware/blob/v3.01-dev/HTTP requests.md
                @dc42 might be able to shed some light on this.
                Danal 1 Reply Last reply Reply Quote 0
                • resam
                  Looks like this is a known limitation of Duet3+SBC:
                  https://github.com/chrishamm/DuetSoftwareFramework/issues/99
                  dc42 created this issue in chrishamm/DuetSoftwareFramework
                  closed Can't upload files from PrusaSlicer #99
                  • Gio
                    Gio last edited by
                    @resam said in DuetRFF Cura plugin Duet 3:
                    RRF HTTP
                    Thanks a lot, let me check.
                    • Gio
                      Gio last edited by
                      If I understand correctly I have to wait for the Ultimaker to update the cure, right?
                      Thanks.
                      • Danal
                        Danal @resam last edited by
                        It is more that RRF3 changed from HTTP to websockets. Standalone or +Pi.
                        That is a very old document. You will find the equivalent over at DWC is in the "legacy" branch (i.e. V1 DWC, V2 RRF)
                        resam 1 Reply Last reply Reply Quote 0
                        • Danal
                          Danal @Gio last edited by
                          Thanks.
                          Cura would be best to update the plugin, they can include it with Cura itself. However, the plugin is open source... anyone could potentially fix it.
                          • resam
                            resam @Danal last edited by
                            @Danal maybe I've missed it - but I'm not aware of any deprecation notice or other announced / communicated changes regarding this...
                            I'm of course fine with releasing a new API - but silently killing the old one is a bit surprising for users and developers trying to integrate tooling and automation with the Duet platform.
                            • Danal
                              Danal last edited by Danal
                              I can certainly see both sides of this (to be clear, I am just a vocal user, I have no formal association with Duet the company).
                              RRF V2 still works fine with 3rd party software written to the APIs published with RRF V2. Nothing has been deprecated.
                              RRF V3 has statements all over the place about how different it is, and that people should not automatically go there, unless they desire feature/function not available in 2. And that they should expect gaps as well as differences. Does it explicitly say the Web API changed? No, absolutely not.
                              So I can see multiple nuances here.
                              Also, I'm fairly certain that Ultimaker (the company that publishes Cura) did not write the DuetRRF plugin. It has to be fetched it from the "marketplace" in Cura.
                              • resam
                                @Danal sorry, I wasn't too clear in the first posts here - I am the author of the Cura Duet-RRF plugin.
                                I pushed a first development branch here: https://github.com/Kriechi/Cura-DuetRRFPlugin/tree/duet3-sbc-DuetSoftwareFramework
                                Since I do not have a Duet3 + SBC print, I was unable to test this - so this is completely untested!
                                @Gio @Danal if you could install the plugin manually and give it a test - and send me the Cura log output back - it would be much appreciated!
                                Please test: simple upload, upload + printing, upload + simulating.
                                Again - this is untested - I have no clue how the DuetSoftwareFramework API behaves - I simply read the documentation and used common sense...
                                wilriker Danal 2 Replies Last reply Reply Quote 1
                                • Sotidii
                                  Sotidii last edited by
                                  [link text]([link url](20200414_102033.jpg link url))
                                    I am discussing with my colleagues the best way to get all the upload plugins working with Duet 3 + SBC. What I don't want is for users to have to choose one of two different plugins according to their Duet configuration, because that would inevitably result in a lot of forum support due to users selecting the wrong one.
                                    • wilriker
                                      wilriker @resam last edited by
                                      @resam I can see the same result as @Sotidii
                                      It seems that the mode-switch is not working. What makes me wonder is that it says 203 Error as if that would be a HTTP/203 return code though when I call this URL directly I get the (correct) HTTP/404.
                                      Manuel
                                      My Tool Collection
                                      • resam
                                        @wilriker Cura uses Qt - and Qt introduced their own error codes:
                                        https://doc.qt.io/qt-5/qnetworkreply.html#NetworkError-enum
                                        i.e., QT 203 means more or less HTTP 404.
                                        @Sotidii @wilriker I pushed another code change to hunt the the problem with the mode switch. Please post parts of your Cura log. On macOS you can find the log under ~/Library/Application\ Support/cura/4.5/cura.log. Or on Windows under C:\Users\<Username>\AppData\Roaming\cura\4.5\cura.log. I'm only interested in lines with Cura-DuetRRFPlugin.DuetRRFOutputDevice in it.
                                        Thanks!
                                        wilriker 1 Reply Last reply Reply Quote 1
                                        • Gio
                                          Gio last edited by
                                          @resam sorry me for delay.
                                          I can't do anything at the moment, I disassembled the printer to finish some works with duet 3
                                          • resam
                                            @Sotidii @wilriker I just realised that my original instructions where probably a bit misleading. Here the correct ones:
                                            Please follow this link to download the correct testing version:
                                            https://github.com/Kriechi/Cura-DuetRRFPlugin/archive/duet3-sbc-DuetSoftwareFramework.zip
                                            Then, with Cura not running, unpack the zip file to this specific folder:
                                            • Windows: C:\Users<username>\AppData\Roaming\cura\4.5\plugins\DuetRRFPlugin
                                            • macOS: ~/Library/Application Support/Cura/4.5/plugins/DuetRRFPlugin
                                            • Linux: /home/<username>/.local/share/cura/4.5/plugins/DuetRRFPlugin
                                            Be careful, the unzipper often tacks on the name of the zip as a folder at the bottom and you don't want it nested. You want the files to show up in that folder.
                                            Make sure that the plugin folder name is a listed above and it does not have any trailing version numbers (-1.0.0) or similar.
                                            • wilriker
                                              @resam Hi Thomas,
                                              first I have to admit that accidentally I was on the wrong branch when testing before. Now I am on the correct branch but still get an issue. I even get a Cura pop-up with a traceback:
                                              Traceback (most recent call last):
                                                File "/home/manuel/.local/share/cura/4.5/plugins/DuetRRFPlugin/DuetRRFOutputDevice.py", line 201, in _check_duet3_sbc
                                                  Logger.log("d", self._name_id + " | rr_connect failed with errorCode " + errorCode)
                                              TypeError: can only concatenate str (not "NetworkError") to str
                                              There is no logging line containing Cura-DuetRRFPlugin.DuetRRFOutputDevice though.
                                              Manuel
                                              My Tool Collection
                                              • resam
                                                @wilriker thanks - almost an expected error.
                                                I pushed another commit - please try again.
                                                wilriker 1 Reply Last reply Reply Quote 0
                                                • Danal
                                                  Been away for a bit, back now.
                                                  Will do.
                                                  • wilriker
                                                    @resam So upload works with latest commit now. Simulating fails with
                                                      File "/home/manuel/.local/share/cura/4.5/plugins/DuetRRFPlugin/DuetRRFOutputDevice.py", line 216, in onUploadReady
                                                        self._stream.seek(0)
                                                    ValueError: I/O operation on closed file
                                                    I could not test printing right now (and won't be able to before tomorrow) but I guess if Simulate works, Start print will also work.
                                                    Manuel
                                                    My Tool Collection
                                                    • resam
                                                      Big shout out to @wilriker for a quick live debugging session!
                                                      It looks like the Cura-DuetRRF plugin now should fully support Duet3+SBC printers.
                                                      I will keep the dedicated branch for a few more days - anyone who is interested in testing, please grab a copy of the plugin here: https://github.com/Kriechi/Cura-DuetRRFPlugin/archive/duet3-sbc-DuetSoftwareFramework.zip
                                                      I plan to upload an updated plugin version into the Cura Marketplace on the weekend. Please let me know if you encounter any issues.
