Duet reporting inaccurate percentage.
Yes the bug is present in the 3.01-RC7 release, but fixed in the post RC7 build that I linked to earlier.
I'm not sure if this issue is connected with my recent move to RRF3.3b2. Since I did, I've had a number of prints telling me they are over 100% complete. Querying the forum I found this thread, and the detail that completion calculation is based on GCODE-embedded filament usage.
In the GCODE file I see:
; filament used [mm] = 13125.43
In DWC, I see this at the end of the print during my cool down phase:
and
The layer count is off, but the filament consumption seems to suggest the reported job completion level should be 99%, not 144.7%.
To add to the mix, I'm also testing ArcWelder, so the GCODE has G2/G3 commands scattered throughout.
One for @chrishamm.
@spoonunit Please share the full G-code file and I'll have a look.
@chrishamm here you go
It's even more exciting in simulation mode - getting to about 354% before then completing and setting itself to 100%.
@spoonunit, please share your config.g fie.
What sort of mixing extruder do you have? In your M567 command(s), is the total mix ratio 1.0?
