    G-code magic for advanced homing?
    Gcode meta commands
    1.3k
    • monsterundefined
      monster
      Is it bay any chance possible that homing script would be able to know if an axis was homed before?
      Why I want it? Because if an axis was homed before and homing requested - then I can go quickly to X10 Y10 quick and then slowly move last one cm to until end switches trigger. If not homed before - then ofc slowly move in relative mode backward until end switch triggered.
      For now if use same logic
      G90               ; absolute positioning
      G1 H1 X10 F1800
      G91               ; relative positioning
      G1 H1 X-290 F600  ; move slowly to X axis endstop once more (second pass)
      works just fine when it was homed before. But if not it actually first moves 10mm away from end switches and then does -290 move, which in case heads were already on the edge of its max X makes terrible skipping drama noses.
      And so I had to comment out "G1 H1 X10 F1800"
      • botundefined
        bot
        I think you could simply tell the toolhead to go to the X10 Y10 position at the beginning of the homing script. If insufficient axes are homed, an error will be generated and it will be ignored (and I think the rest of the homing script will be completed). If sufficient axes are homed, you'll get the desired movement and then the rest of the homing script.
        However, if a motor has lost position, the command to go to X10 Y10 could cause a crash.
        *not actually a robot
        • littlehobbyshopundefined
          littlehobbyshop
          https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Examples_of_use
          There is an example of homing at the bottom of the article, you'll probably only want the first few lines, this will tell you if the axes are already homed:
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
          You will need firmware version 3.0.1 or later to run conditional gcode.
          BLV MGN Cube w/Hemera, K8200, Sunlu S8
          • monsterundefined
            monster
            Thank you both of you guys!
            • deckingmanundefined
              deckingman @monster
              @monster It looks like you are sorted but yet another alternative is to do a coarse homing move at high(ish) speed, back off a few mm , then do a second fine homing move at slow speed. So something like:
              G91
              G1 H1 X-290 F1800
              G1 X10 F600
              G1 H1 X-20 F600.
              • monsterundefined
                monster
                @deckingman I actually seen that 2 pass homing technique, yes it is quick but feels not ideal 😄 What seems to be not ideal here is bounce back. I kinda see more enjoyable fast way forward with slowing down when close to expected home switch 😉
                monsterundefined 1 Reply Last reply Reply Quote 0
                • monsterundefined
                  monster @monster
                  @monster said in G-code magic for advanced homing?:
                  Or actually!!! What I could do is if previous homing detected that it will be one way, else 2 pass technique 😉
                  deckingmanundefined monsterundefined 2 Replies Last reply Reply Quote 0
                    deckingman @monster
                    Yes, why not? Sounds like a plan to me..........
                    • monsterundefined
                      monster @monster
                      Something doesn't seem as I'd expect...
                      ; quickhomexy.g
                      G90
                      if move.axes[0].homed && move.axes[1].homed && move.axes[2].homed
                      	M98 P"quickhomexy_singlepass.g"
                      else
                      	M98 P"quickhomexy_doublepass.g"
                      Strange both M98 P"quickhomexy_singlepass.g" and M98 P"quickhomexy_doublepass.g" get called.
                      If construction doesn't work for some reason.
                      littlehobbyshopundefined 1 Reply Last reply Reply Quote 0
                      • botundefined
                        bot
                        I'm not sure about in RRF 3, but in RRF 2, the moment you press home, the axis is flagged as unhomed (at least, it shows as such in DWC). Perhaps, the axes are all flagged as unhomed right before your conditional statement is called?
                          littlehobbyshop @monster
                          @monster What version of DWC are you running?
                          It may be you have an older version of DWC. Initially when pressing tab it was putting in the wrong indentation. In that case you either need to update DWC and redo those indented lines with the tab key or replace those tabbed indents with 4x spaces.
                          • monsterundefined
                            monster
                            @littlehobbyshop
                            Version:
                            Board: Duet 3 MB6HC (MB6HC)
                            DSF Version: 1.2.4.0
                            Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
                            @bot
                            That axis gets unhomed I did figure out. That is sad.
                            But hey, how come both parts of IF are executed - that is quite a feature 😂
                            I tested it now with messages (which aren't working correctly them-self) and with sounds. Seems like IF is out of scope 😞
                            I guess what is left is what you said "tell the toolhead to go to the X10 Y10 position at the beginning of the homing script."
                            But then again once home requested it might be invalidated by unhoming all. I need to test it...
                            botundefined dc42undefined 2 Replies Last reply Reply Quote 1
                            • botundefined
                              bot @monster
                              @monster Ha! You're right, it might not be able to make any move whatsoever because of the unhomed flag.
                                littlehobbyshop
                                @monster did you try replacing those indents with 4 spaces?
                                • monsterundefined
                                  monster
                                  @bot hold on a sec! This part I already know! Basically if it homed before that my command in homing subroutine go to X10 Y10 works! So perhaps it is unhomed but still knows where is 10,10....
                                  Bit weird though.
                                  botundefined 1 Reply Last reply Reply Quote 0
                                  • botundefined
                                    bot @monster
                                    @monster That is very interesting. So it moves to X10 Y10 if homed, and then continues with the script? But it omits the X10 Y10 movement if not homed?
                                    Perhaps, as you say, it's not getting flagged as unhomed right away, and you need to indent the script as @littlehobbyshop says.
                                    • monsterundefined
                                      monster @littlehobbyshop
                                      @littlehobbyshop said in G-code magic for advanced homing?:
                                      Nope:
                                          M300 S300 P200
                                      else
                                          M300 S100 P200
                                      This plays (via webui) S100 sound
                                          M300 S300 P200
                                      ;else
                                      ;    M300 S100 P200
                                      and this plays S300 sound
                                      • monsterundefined
                                        monster @bot
                                        @bot said in G-code magic for advanced homing?:
                                        Not exactly.
                                        If homed before then it goes to 10,10 and then by relative moving goes to 0,0
                                        if not homed then (i believe) it takes that X10 Y10 to move 10mm in opposite direction (away from end swithces) and then by relative moving still gets parked on 0,0
                                        • monsterundefined
                                          monster
                                          @littlehobbyshop is there way to see a value of variable?
                                          display it in message?
                                          or much better would be to display it in log?
                                          something like
                                          "log move.axes[0].homed"
                                          by anychance?
                                          edited
                                          found this https://duet3d.dozuki.com/Wiki/Gcode#Section_M409_Query_object_model
                                          but
                                            deckingman @monster
                                            @monster This does beg the question, if an axis is homed, why do you want to home it again? Or am I missing something?
