    WiFi module doesn’t turn on when printer is turned on
    • Asabolundefined
      Asabol
      After setting up my duet 2 WiFi board and plugging the printer in. The board turns on but the WiFi module doesn’t turn on or show indication through the led that it is on. What can I do to resolve this issue. I set up the configuration on the board before plugging the parts of the 3D printer in to the spec of the guide on dozuki.
      • A Former User?
        A Former User
        Connect a usb cable and use the serial console to see what messages are printed when the printer is turned on.
        and/or
        attach your config file.
        • Asabolundefined
          Asabol
          When having it plugged into a usb cable on a Mac it is suppose to show a line that says USB modem then a number but it just shows that there is just a Bluetooth incoming port and no usb attached device.
            Try different USB cables or a different PC entirely
