    Switching from Stable to Unstable versions
    Firmware installation
    266
    • monster
      monster last edited by monster
      I just used https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Duet_3_RepRapFirmware_notes
      in order to get me latest RC
      log file of my console to Pi is attached (in case I did some stupid move).
      log.txt
      Now it sits in last line for too long:
      pi@beast:~ $ sudo apt-get upgrade
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      Calculating upgrade... Done
      The following packages have been kept back:
        binutils binutils-arm-linux-gnueabihf binutils-common libbinutils libgl1-mesa-dri libjavascriptcoregtk-4.0-18 libwebkit2gtk-4.0-37 mesa-va-drivers mesa-vdpau-drivers pcmanfm
      The following packages will be upgraded:
        duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware
      8 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
      Need to get 32.4 MB of archives.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] Y
      Get:1 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 1.3.2 [1,706 B]
      Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsd all 1.0.6 [2,010 B]
      Get:3 https://pkg.duet3d.com unstable/armv7 armhf duettools armhf 1.3.2 [50.3 kB]
      Get:4 https://pkg.duet3d.com unstable/armv7 armhf duetcontrolserver armhf 1.3.2 [176 kB]
      Get:5 https://pkg.duet3d.com unstable/armv7 armhf duetruntime armhf 1.3.2 [28.8 MB]
      Get:6 https://pkg.duet3d.com unstable/armv7 armhf duetwebserver armhf 1.3.1 [71.4 kB]
      Get:7 https://pkg.duet3d.com unstable/armv7 armhf duetwebcontrol all 2.1.2 [2,815 kB]
      Get:8 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 1.3.2-1 [478 kB]
      Fetched 32.4 MB in 18s (1,838 kB/s)
      Reading changelogs... Done
      (Reading database ... 79400 files and directories currently installed.)
      Preparing to unpack .../0-duetsoftwareframework_1.3.2_armhf.deb ...
      Unpacking duetsoftwareframework (1.3.2) over (1.2.4.0) ...
      Preparing to unpack .../1-duetsd_1.0.6_all.deb ...
      Unpacking duetsd (1.0.6) over (1.0.5) ...
      Preparing to unpack .../2-duettools_1.3.2_armhf.deb ...
      Unpacking duettools (1.3.2) over (1.2.4.0) ...
      Preparing to unpack .../3-duetcontrolserver_1.3.2_armhf.deb ...
      Unpacking duetcontrolserver (1.3.2) over (1.2.4.0) ...
      Preparing to unpack .../4-duetruntime_1.3.2_armhf.deb ...
      Unpacking duetruntime (1.3.2) over (1.2.4.0) ...
      Preparing to unpack .../5-duetwebserver_1.3.1_armhf.deb ...
      Unpacking duetwebserver (1.3.1) over (1.2.3.1) ...
      Preparing to unpack .../6-duetwebcontrol_2.1.2_all.deb ...
      Unpacking duetwebcontrol (2.1.2) over (2.0.7-1) ...
      Preparing to unpack .../7-reprapfirmware_1.3.2-1_all.deb ...
      Unpacking reprapfirmware (1.3.2-1) over (1.2.4.0-1) ...
      Setting up duetruntime (1.3.2) ...
      Setting up duetwebcontrol (2.1.2) ...
      Setting up duetcontrolserver (1.3.2) ...
      Installing new version of config file /opt/dsf/conf/config.json ...
      Setting up duettools (1.3.2) ...
      Setting up duetwebserver (1.3.1) ...
      Installing new version of config file /opt/dsf/conf/http.json ...
      Setting up duetsd (1.0.6) ...
      Setting up reprapfirmware (1.3.2-1) ...
      Sending update request to DCS...
      and nothing happens.
      What to do? 🙄
      added later:
      It is Duet 3 + Pi
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @monster last edited by
        @monster said in Switching from Stable to Unstable versions:
        the update shouldn't take more than a minute or two, so anything more than that is likely a failure.
        with a bit of luck, reset the duet and when its back up try echo M997 S0| sudo /opt/dsf/bin/CodeConsole
        if that doesn't work you can try to recover it by usb and bossa
        • monster
          @bearer
          pi@beast:~ $ echo M997 S0| sudo /opt/dsf/bin/CodeConsole
          Connected!
          pi@beast:~ $
          WebUI up and
          Board: Duet 3 MB6HC (MB6HC)
          DSF Version: 1.3.2.0
          Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC7 (2020-04-14b3)
          Note: You can install updates on the System page.
          • A Former User
            A Former User last edited by
            so all good?
            • monster
              I'm not sure.
              I tried to run this test macro (hoping that IF will work in RC7)
              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                  M300 S300 P200
              else
                  M300 S100 P200
              And got: Code isn't supported
              And M300 S100 P200 is being sent to controller with no error replied, though no sound produced. This is new behavior.
              • monster
                Though homing happens...
                  Conditional Gcode isn't yet supported on Duet3+Pi, but is coming soon.
                  • monster
                    I've been using M300 in debug purposes. Figuring out which *.g script just being run or in which part of the script printer now.
                    In case M300 isn't producing any sounds anymore what would be my method to do this kinda feed back messages?
                      You can use M117. You can use object model variables in the M117 command if it helps.
                      • monster
                        One finding since yesterdays RC7 installation.
                        I started to get (while homing) error message
                        G28 Z
                        Error: Code is not supported
                        And I started to figure out where do I have that command. (Btw according to https://duet3d.dozuki.com/Wiki/Gcode#Section_G28_Home that shouldn't cause any errors but anyway)
                        Then I did download all files from my system directory and searched for "G28" in all *.g files.
                        And I found one occasion "G28" (without Z parameter) in my start.g which isn't called during homing.
                        This is why I writing here is there a chance of a bug? That somehow "G28 Z" called automatically? Perhaps when WebUI "Home Z" pressed?
                        And why it does produce error message...?
                          dc42 administrators @monster last edited by dc42
                          Exactly. G28 Z should be recognised, it is equivalent to G29 Z0. The value of the parameter is ignored.
                          Are you sure that the error message isn't related to a different command? Although normally the command G- or M-code would be included in the error message.
                          • monster
                            I took a screenshot to show that the error message appears by the end of homingz
                            Homing z code is below (sorry it is messy at the moment)
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Mar 30 2020 01:10:04 GMT+0300 (Eastern European Summer Time)
                            G91               ; relative positioning
                            ;G1 Z10 F500 		; lower the bed slowly because it can already be in lowest position
                            G90
                            M98 P"quickhomexy.g"
                            G90              ; absolute positioning
                            ;if move.axes[0].homed && move.axes[1].homed && move.axes[2].homed
                            ;	G1 H2 X150 Y150 Z15 F3000  ; move quickly to X and Y axis middle (where Z home trigger is) and at the same time bring Z to 15mm befor home spot
                            ;else
                            G1 H2 X150 Y150 F4000  ; move quickly to X and Y axis middle (where Z home trigger is) not moving Z
                            ;G1 H2 Z10 F2000    ; move quickly to 10cm away from expected home
                            G1 H1 Z-200 F500 ; move Z down until the endstop is triggered
                            ;G92 Z0            		; set Z position to axis minimum (you may want to adjust this)
                            G92 Z2.8
                            ;G91              ; relative positioning
                            ;G1 Z10 F2000       ; lift Z relative to current position
                            M117 "End of Z homing"
                            So I could say yes I'm sure.
                              Please post the contents of quickhomexy.g too.
                              • monster
                                Quickhomexy.g
                                ; quickhomexy.g
                                ; called to home x and y axes
                                M117 "Quick homing X&Y begin"
                                G90
                                ;if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                ;  M98 P"quickhomexy_doublepass.g"
                                ;else
                                ;  M98 P"quickhomexy_singlepass.g"
                                else
                                ;G1 H1 X-300 Y-300 F900  ; move slowly to X and Y axis endstops once more (second pass)
                                M117 "Quick homing X&Y end"
                                and
                                ;M98 P"quickhomexy_doublepass.g"
                                ;M291 P"Double"
                                M117 "Double pass X&Y homing"
                                G90
                                G1 H1 X10 Y10 F5000
                                G91
                                G1 H1 X-300 Y-300 F4000
                                G1 X10 Y10 F600
                                G1 H1 X-20 Y-20 F600
                                and
                                ;M291 P"Single"
                                ;M300 S200 P100 					; play beep - debug sound
                                M117 "Single pass X&Y homing"
                                G90
                                G1 H1 X10 Y10 F2000 	; move quickly to X and Y axis to 10cm away from expected home (first pass)
                                G1 H1 X-20 Y-20 F900  ; move slowly to X and Y axis endstops once more (second pass)
                                • monster
                                  by the way is "move.axes[0].max" is available in RC7 ?
                                  Also is there way to define own constants? E.g. I could define X Y coordinates at witch magnet for Z endswitch is locates and refer to those constants in homing g files.
                                    Yes.
                                    Not yet, this is scheduled for firmware 3.02.
