    Duet Wifi extrusion nightmares.
    • Lord Jambrek
      Lord Jambrek last edited by
      Hi guys.
      I bought the board about 3 weeks ago and I still can't get a normal print from day 1 whatever I do. Everything is calibrated and tested with a caliper so steps per mm are alright. Here is a pic of my lats print. It started normally but then it made the first layer of infill which went fine and the second infill layer started with the inconsistency and then it started doing the top layer and did this mess. Mechanically everything is the same as with the previous board and I copied the extruder settings from marlin (it printed flawlessly on the previous board).
      The setup is a E3D V6 original with MK8 all metal extruder. These symptoms appear no matter the speed or the settings, it's like the board is handling the extrusion with a mind of it's own, regardless of my settings.
      Here are some pics:
      Here is my Config.g
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X200 Y200 Z180 S58 ; Set axis maxima
      M574 X1 Y1 E0 S0 ; Define active low and unused microswitches
      M558 P4 X0 Y0 Z1 H2 F120 T8000
      G31 P1000 01 Y0 Z1.60 ; Set Z probe trigger value, offset and trigger height
      M557 X0:160 Y25:180 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X79.92 Y80.31 E100.96 Z2560 ; Set steps per mm
      M566 X780 Y780 Z18 E300 ; Set maximum instantaneous speed changes (mm/min)
      M203 X24000 Y24000 Z120 E5400 ; Set maximum speeds (mm/min)
      M201 X1400 Y1400 Z100 E80000 ; Set accelerations (mm/s^2)
      M906 X770 Y770 Z770 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      M550 PGewera ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      • jstevewhite
        jstevewhite last edited by
        What slicer are you using? Is it configured for absolute or relative E steps? If absolute, you have to add the M82 in the startup g-code to switch RRF to absolute extrusion. Just a problem I ran into with Cura (which doesn't seem to support relative extrusion).
        • vwegert
          vwegert last edited by
          I got similar results (on a non-Duet printer) when the extruder had to apply excessive force to pull the filament from the spool - did you check that your filament path is not the issue?
            Can you post some higher-resolution pics on a file sharing site?
