    Wifi stuck in starting
    Duet Web Control
    • wdenkerundefined
      wdenker
      M552 shows wifi continues to start and is stuck. I have flashed all of the 2.02 release without any issue. M552 S0 won't out it in idle either. Any ideas?
      www.bd3dcustoms.com | BD3DCUSTOMS Supercube
      • A Former User?
        A Former User
        1. it help to show the actual output, copy/paste from terminal.
        2. 2.02 is not the latest release, it is 2.05.1
        3. RRF 2.05.1 needs wifi version 1.23
        4. include the output of the M122 command
        5. did it work previously?
        • wdenkerundefined
          wdenker
          I use 2.02 on all of my current machines. I have setup over a dozen like this without an issue. M122 all came back fine. The board is on its way back to the supplier.
          • wdenkerundefined
            wdenker
            @dc42 if I can get confirmation the board is indeed have issues the supplier will give me a refund since they are out of stock. Can you confirm please?
              @wdenker said in Wifi stuck in starting:
              1. Do mean that M552 says "WiFi module is starting" whenever you run it?
              2. What happens if you upload version 1.23 of DuetWiFiserver.bin to /sys, then run M997 S1 to install it? Does that succeed, and if so does it fix the problem? It's best to have a terminal connected via USB when doing that, or a PanelDue, so that you can see the update progress.
              wdenkerundefined 1 Reply Last reply Reply Quote 0
              • wdenkerundefined
                wdenker @dc42
                @dc42 yes it does succeed and still shows starting.
                  Phaedrux Moderator @wdenker
                  @wdenker On behalf of @dc42 your warranty request is approved. Sorry for the bother and thank you for your patience.
