    Duet emulator
    DSF Development
    • Gio
      Gio last edited by
      I have finished installing the various development environments and would like to start developing the GUI. Is there any way to simulate the duet 3 card or should I always have the raspberry connected to the duet3 card?
      Thank you.
      • bberger
        bberger last edited by
        Yeah, that's a thing I'd also know.. is there something like a mock API for RRF3?
        It was/is a bit funky trying to develop on the DWC on a live backend..
        • Danal
          Danal last edited by
          At what level do you intend to interface? The Unix internal socket? The Web Socket?
          I can tell you what I do to develop: A mix of the actual printers around here, and a Duet 2 board (running RRF2 or 3 on different days) sitting on a bench with a couple of steppers plugged in sitting a few inches away from it. I have the (non-existent) endstops on that 'system' configured to be "always triggered" so that I can "home" it. Mostly, I don't have heaters or sensors or things.
          That's really it for the test rig. Occasionally, I will plug an extra switch or sensor or motor or whatever into that test harness... but... in reality, I usually just re-point from the test harness to a printer if I need something more.
          Not at all saying this is the perfect setup; for me, it is productive.
          • Gio
            Gio last edited by
            I believe I will use DuetSocketFramework but I have yet to start. I wasted too much time installing qt on windows! 🙂
            So the only solution is to buy a Duet card to do software development, it seems cheap! 🙂
            I was hoping there was a simulator or something like that at least for the main functions.
            Thank you.
