    [HELP] How to use DueUI without a Duet using chrome
    DueUI
    3.3k
    • gtj0undefined
      gtj0 @Dario02
      @Dario02 header_panel and menubar are fixed because that's what the class DueuiTabbedPanel in dueui_panel.js expects them to be. You can't change them and there's no reason to change them. What you put in those variables has id fields and that's how you refer to them. For instance...
      /* This has to be "dueui_content" because that's what the code expects. */
      dueui_content = {
      	 * But the value of "id" can be anything you want.
      	 * This is how you'd refer to the element using jQuery...  #my_top_tabbed_panel
      	"id": "my_top_tabbed_panel",
      	"type": "tabbed_panel",
      	/* Same here.  This has to be "header_panel" because the code expects it. */
      	"header_panel": {
      		/* But you can set its id to anything you want and reference it as #<id>. */
      		"id": "main_header_panel",
      		"type": "panel",
      	/* Same again.  This has to be "menubar" because the code expects it. */
      	"menubar": {
      		"id": "main_dueui_menubar",
      		"type": "panel",
      		"button_defaults": {
      			"style": {
      				"margin-right": "5px"
      Dario02undefined 1 Reply Last reply Reply Quote 0
      • Dario02undefined
        Dario02 @gtj0
        @gtj0 Are there others fixed defintion that I should know? If yes where can I find them?
        gtj0undefined 1 Reply Last reply Reply Quote 0
        • gtj0undefined
          gtj0 @Dario02
          @Dario02
          Anything on the left side of an "=" or ":" inside "dueui_content", including "dueui_content" itself, is fixed because that's how the Javascript code finds it.
          Same for "status_map". Those key names are what the Duet firmware sends for statuses.
          • Dario02undefined
            Dario02
            @gtj0 You asked me to report you what examples don't work. For now I found:
            https://github.com/gtjoseph/DueUI/wiki/File-List
            https://github.com/gtjoseph/DueUI/wiki/Heater
            • gtj0undefined
              gtj0 @Dario02
              @Dario02 When you say "'don't work" what do you mean? Can you share the JSON you used to configure them?
              • Dario02undefined
                Dario02 @gtj0
                @gtj0 simply if I add one of them the code doesn't run
                • Dario02undefined
                  Dario02
                  @gtj0 try adding one of them, now I can't
                  class DueUIConfig {
                    "dueui_content" = {
                      "id": "dueui",
                      "header_panel": {
                        "id": "dueui_header_main",
                        "type": "panel",
                        "element_configs": [
                            "id": "video_html",
                            "type": "image",
                            "src": "http://192.168.1.118/rr_download?name=/images/logo.png",
                            "style": {
                              "width": "128px",
                              "height": "41px"
                            "position": {
                              "my": "left top",
                              "at": "left top",
                              "of": "#dueui"
                            "id": "status",
                            "type": "status",
                            "style": {
                              "width": "128px"
                            "position": {
                              "my": "left top",
                              "at": "right-115 top+3",
                              "of": "#dueui"
                      "menubar": {
                        "id": "dueui_menubar",
                        "type": "panel",
                        "button_defaults": {},
                        "position": {
                          "my": "left top",
                          "at": "left+8 bottom-28",
                          "of": "#dueui"
                          "id": "dueui_panel_movement",
                          "type": "tab_panel",
                          "menubar_label": "HOME",
                              "id": "video_html",
                              "type": "image",
                              "src": "http://duet3:8080/stream",
                              "style": {
                                "width": "320px",
                                "height": "210px"
                              "position": {
                                "my": "left top",
                                "at": "left top",
                                "of": "#dueui_panel_movement"
                    "status_map" = {
                      "idle": { "label": "Idle", "classes": "btn-success" },
                      "P": { "label": "Printing", "classes": "btn-success" },
                      "S": { "label": "Stopped", "classes": "btn-warning" },
                      "C": { "label": "Starting Up", "classes": "btn-success" },
                      "paused": { "label": "Paused", "classes": "btn-primary" },
                      "pausing": { "label": "Pausing", "classes": "btn-success" },
                      "resuming": { "label": "Resuming", "classes": "btn-success" },
                      "changingTool": { "label": "Tool<br>Change", "classes": "btn-warning" },
                      "busy": { "label": "Busy", "classes": "btn-success" },
                      "updating": { "label": "Updating", "classes": "btn-danger" },
                      "halted": { "label": "Halted", "classes": "btn-danger" },
                      "off": { "label": "Off", "classes": "btn-danger" },
                      "processing": { "label": "Processing", "classes": "btn-warning" },
                      "simulating": { "label": "Simulating", "classes": "btn-primary" },
                      "connected": { "label": "Connected", "classes": "btn-success" },
                      "connecting": { "label": "Connecting", "classes": "btn-warning" },
                      "reconnected": { "label": "Connected", "classes": "btn-success" },
                      "disconnected": { "label": "Disconnected", "classes": "btn-warning" },
                      "retrying": { "label": "Retrying", "classes": "btn-warning" },
                      "failed": { "label": "Failed", "classes": "btn-danger" },
                      "unknown": { "label": "?", "classes": "btn-secondary" }
                  • gtj0undefined
                    gtj0 @Dario02
                    @Dario02 I'm sorry but I don't understand. The json you posted seems to work fine but doesn't have either a file list or a heater in it to test.
                    • Dario02undefined
                      Dario02 @gtj0
                      @gtj0 Yes it works fine because I removed what didn't work... as I told you try adding one of the element/widget that I reported you and the code should not work properly. If you can't understand what I mean, please wait until I'll be free to work on this with you ^_^
                      • gtj0undefined
                        gtj0 @Dario02
                        @Dario02 OK, when you get a chance, I'll need you to send me the exact json configuration you tried that didn't work.
                        • Dario02undefined
                          Dario02
                          @gtj0 I managed one error you didn't write the "," after "standby": "G10 P0 S${value}"
                          } <---- missing ","
                          "set_temp_commands": {
                          				"active": "G10 P0 R${value}",
                          			 * The two input fields for setting the active and standby can be hidden
                          			 * if desired.  The default is to show them.
                          			 "show_set_fields": false
                          it should be:
                          • gtj0undefined
                            gtj0 @Dario02
                            @Dario02 Ah, yeah that's an issue. I'll fix that. Also I think I reversed the "R" and "S" parameters. "active" should be "S" and standby should be "R". I'll fix that as well.
                            • Dario02undefined
                              Dario02 @gtj0
                              @gtj0 ok well, I'll let you know for the other error
