    my second raspberry has just passed away
    Duet Web Control
    9
    102
    5.9k
    • spllgundefined
      spllg @dc42
      1. no servo but i'm thinking of installing one - how to do this in a secure way?
      2. none of the stepper bodies is grounded. should i ground the steppers?
      generally: what additional precautions should i take? what documentation did i miss?
        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
        • A Former User?
          A Former User @spllg
          @spllg said in my second raspberry has just passed away:
          the display keeps dark
          haven't tested how the pi4 reacts, but the previous will always display the 4 pixel interpolated rainbow thing before attempting to boot the kernel. it could be different if the boot eeprom is corrupted, but according to the internet the odds of that happening should be pretty slim.
          but that you're not getting any output suggest the hdmi driver is done, or the cpu isn't even getting to the bootloader
          spllgundefined 1 Reply Last reply Reply Quote 1
          • spllgundefined
            spllg @A Former User
            @bearer can't get any info from the rpi - green led is unevenly blinking 3-4 times and than is switched off.
            going tom buy a new rpi (€60). i will not 5v-power the duet from the rpi and see how long the rpi will be alive - hopefully longer than 4 month. if it will die again i will consider to try another board as i haven't got the time to mess around with hardware problems!
            btw.: i remember the rpi freezed several times (days before) before it died.
            A Former User? A Former User? 2 Replies Last reply Reply Quote 0
            • A Former User?
              Buy an Rpi3B+ from a reputable source, use the external 5v in (with a suitable amperage PSU) to provide system power to the Duet-3 which will then push the voltage TO the Rpi (with the correct jumpers being in place on the Duet-3) that combination is 100% working on multiple Duet-3's and has been for months for me with NO issues.
              if you still cant work it out I would be willing to purchase the secondhand board from you as you are obviously unable to operate it properly.
              spllgundefined 1 Reply Last reply Reply Quote -1
              • spllgundefined
                @CaLviNx i could operate the rpi using 5v-power from the duet but i would loose the ability to switch off duet's psu when the print has finished.
                seems you are looking for a cheap board.
                ok, it seems, i am unable to operate it correctly after i was able to do so for 4 monthts. wondering what the change could be.
                i understand: i'm on my own!
                A Former User? A Former User? 2 Replies Last reply Reply Quote 1
                • A Former User?
                  i think he meant use a 24v/12v for vin and a 5v for 5v_ext supply; as such you could still turn off vin
                  • A Former User?
                    @spllg
                    Please correct me if i am wrong but YOU Said (and I quote)
                    " if it will die again i will consider to try another board as i haven't got the time to mess around with hardware problems!"
                    logic would dictate that you will move away from the Duet Platform it would leave a perfectly good board not being utilized as you own words (again i quote)
                    "i haven't got the time to mess around with hardware problems"
                    So my offer was to assist you in not having to suffer a total loss of the financial burden you endured to purchase the equipment.
                    I am luckily in a financial position to not seem like i need to be (as you say, and i quote yet again) "looking for a cheap board"
                    Also if you know what you are doing you can utilize the SBC to automatically control ALL the PSU's when a print has finished, Which Bearer managed to work out.
                    You also seem to have changed your outlook, previously you said (I quote)
                    " i feel the duet is somewhat responsible for the deaths"
                    To now saying (I quote)
                    "wondering what the change could be"
                    The Words (I quote)
                    "i understand: i'm on my own!"
                    Are factually incorrect, because the FACTS are that numerous users are trying offer you information and some are going as far as to explain things you are not able to work out on your own, so no you are not on your own.
                      Now now, we're here to be helpful. If we're not being helpful, don't be here.
                      spllgundefined 1 Reply Last reply Reply Quote 0
                      • A Former User?
                        i designed this a while back, but still haven't built one to test, mainly because i don't currently have a duet3
                        https://easyeda.com/bearer/duet36hc-isolator
                        back to the pi, it'd be interesting to have the boot eeprom removed or re-flashed via spi to rule out that. beyond that i think maybe turning to the pi forums to get help with a postmortem would be the way to go to get to the bottom of what is happening.
                        spllgundefined 2 Replies Last reply Reply Quote 0
                        • spllgundefined
                          spllg @Phaedrux
                          @Phaedrux you mean, i should leave - this is the only support for a €270 board.
                          • spllgundefined
                            @bearer because the rpi died while printing i do not feel it could be reactivated by reflashing the boot eeprom but i will try it laster.
                            • A Former User?
                              odds are indeed low, but seems the "simplest" option without having it sent off somewhere for more in depth analysis.
                              there are a couple of test points to check voltage rails, but afaik all are generated from the same chip, so odds are its okay as the green led blinks
                              https://www.raspberrypi.org/documentation/hardware/raspberrypi/schematics/rpi_SCH_4b_4p0_reduced.pdf
                              • spllgundefined
                                @bearer isolator: so i assume that the duet is not isolated. unfortunately i did not find this info in the duet docs.
                                • A Former User?
                                  A Former User
                                  they're not isolated no; there is a series resistance to prevent damage; which seems to be sufficient for everyone else. (i drew the isolator to protect the pi when testing the duet 3, testing finished and duet survived before the board was finished so it was never made)
                                    Here's an update of our perspective.
                                    • We originally designed the Duet 3 5V supply to be able to handle RPi 3B+ plus some power to USB peripherals. Since then, the RPi 4 has become the norm, and it needs significantly more power.
                                    • We've seen a few cases of the Duet 5V supply being overloaded. It turned out to be less resilient when overloaded than we designed for. So in revision 1.1 we made some changes, including adding a 3A PTC fuse.
                                    • For the future, we're considering uprating the maximum VIN voltage to 50V (so that you can use a 48V PSU). This will mean we need to reduce the 5V current rating, so we would remove the option to power the RPi from the Duet. I think this is reasonable, given the market switch to RPi 4.
                                    • We've no reason to believe that there is any problem with the original connection arrangement between the Duet and the RPi even when they are powered from different 5V supplies, subject to the caveat below. However, in order to eliminate any possible issues caused by differing supply voltages, we've added level shifters between the Duet and the SBC interface in Duet 3 revision 1.1; apart from the SS signal, for which we've increased the value of the series resistor to 1K.
                                    Caveat:
                                    It is mandatory that the Duet, RPi PSU, and any PC that the RPi is connected to via USB are powered from the same power distribution block, or double/triple socket outlet. If you don't do this then you may suffer from transients caused by other mains-powered equipment or lightning etc. and poor mains wiring. In addition, if the PSUs of two or more of the devices have a connection between mains ground and output negative, or you connect the RPi via USB to a PC or other device with a ground connection, and one of the output negative connections is poor, then there may be a substantial current in the Duet to RPi ribbon cable ground connection. In particular, if the VIN- connection between the Duet and its PSU is poor, then the bed current may try to flow through the ribbon cable. This is exactly the same issue as explained at https://duet3d.dozuki.com/Wiki/USB_ground_loops.
                                    The RPi PSUs that I have seen do not have a connection between mains ground and output negative. PCs always do have a connection between mains ground and USB common. Laptops often do too, when running from mains power.
                                    • spllgundefined
                                      spllg @dc42
                                      @dc42 clarification: i did not power the duet via the usb (i did with my forelast one). instead i powered the rpi using an original rpi psu and powered the duet via the ribbon cable (5v->sbc and sbc->5v both closed as instructed by dc42). i did this in order to be able to switch the 24v psu on and off using the web interface.
                                      as i am not an electronic engineer, i considered to 5v-power the duet and the rpi using 2 distinct psus (with 5v->sbc and sbc->5v both open) but now i feel, the only safe way to use the duet with a rpi (3+ not 4) is to power the rpi3+ from the duet (with 5v->sbc closed and sbc->5v open).
                                      i will power the rpi from the duet, ground the stepper cases and see how long my next rpi will stay alive.
                                      • spllgundefined
                                        spllg @spllg
                                        @spllg if i power the rpi form the duet i will loose the ability to switch the duet psu on using the web interface. any suggestions?
                                        • A Former User?
                                          if you only have a single supply for the duet yes. if you have a dedicated 5v supply for the duet, no (can't be a dc/dc off the main supply ofc)
                                          • spllgundefined
                                            @bearer i was told )by a person who knows how to operate the duet device) to do it this way. just wanted to point out that i lose functionality when following his advice.
                                            rgds.
