    Fan control temp. problem
    137
    • secure
      secure last edited by secure
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0.3 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1                                      ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H2                                      ; set fan 2 value. Thermostatic control is turned on
      Even though there is no "T" set temperature M106 P1 or P2 turns with "M106 P1
      Fan 1, speed: 0%, min: 10%, max: 100%, blip: 0.10, temperature: 45.0:45.0C, sensors: 1, current speed: 0%:"
      I didnt set the temperature: 45.0:45.0C how does this comes out with that settings? Now I cant control the fans if the temp is below 45c
        If you want to control the fans use H-1 to disable thermostatic control.
        If you want thermostatic control, define your own temperature range with a T parameter.
        45c is the default used in the firmware likely due to that being used for the hotend fans by default.
        • secure
          Thanks. When I do this(H-1) I am loosing my fan control over DWC. It says no fans.
          May last configration was like this and it was working very well.
          M106 P0 S0.3 I0 F500 H-1                             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S0 I0 F500 H-1                               ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P2 S0 I0 F500 H-1                               ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          These two fans are for part cooling. Extruder fans are always on.
          • secure
            BTW is there any Gcode for clearing Duet board cache? Sometimes I feel like my config.g is not updated.(config.override is cleared)
              Phaedrux Moderator @secure last edited by
              @secure said in Fan control temp. problem:
              What version of DWC are you using?
              Do you see a text label that says Fan Visibility?
              What fan do you have defined in your tool definition (M563)?
              • secure
                Duet Web Control 2.1.3
                There is no "Change visibilty" It says just no fans.
                M563 P0 S"E1" D0 H1 F1				     ; Define tool E1
                M563 P1 S"E2" D1 H2 F2                               ; Define tool E2
                G10 P0 X0 Y0 Z0                                    ; Set tool E1 axis offsets
                G10 P1 X-32.50 Y0 Z0                                 ; Set tool E2 axis offsets
                G10 P0 R0 S0                                         ; Set initial tool 0 active and standby temperatures to 0C
                G10 P1 R0 S0 					     ; Set initial tool 0 active and standby temperatures to 0C
                This config was working before I updates to DWC 2.1.3
                • secure
                  Back to Duet Web Control 2.0.4 fixed. @chrishamm
                    Try 2.0.7.
