    workbee control on duet 3
    Duet Web Control
    • tristanryerparkeundefined
      tristanryerparke
      I just set up my duet 3 with a raspberry pi.
      I am upgrading a cnc machine from duet 2 wifi to duet 3 and am wondering if I can use the workbee control on the pi so that I can see the machine/work coordinates. Or maybe just show the machine coordinates as well as work coordinates in the duet 3 web control.
      Thanks,
      T
        jay_s_uk
        It may be possible to build the latest version from the sources but its built on DWC 2.0.4 which is pretty out of date now.
        The changes need porting across to the latest DWC version but its not staying still long enough to do so at the moment.
          tristanryerparke
          could I modify the newer dwc to show the work/machine coordinates ?
            jay_s_uk
            The source for the ooznest version is here https://github.com/lockryan/DuetWebControl/tree/workbeecontrol
            The source for the current DWC is here https://github.com/lockryan/DuetWebControl/tree/workbeecontrol
            • Tsolsiundefined
              Tsolsi
              Did you manage to make this work at all? If so do you happen to have the config files associated with it for the Duet 3? I'm also trying to get a workbee - like machine (the Lead 1515) to work on the duet 3 but I'm sooo stuck right now, don't know how to begin really.
