    Can "extruder control" control buttons be customized?
    • Robathomeundefined
      Robathome
      I've never intentionally used the default feedrate of 30 mm/s, and 100 mm/s is completely out of the question. If I accidentally click "Extrude" without switching to a slower feedrate, 9 times out of 10 it will chew up the filament beyond recovery before it will extrude anything. I think it would be fantastic if a) the feedrate values on the buttons could be customized, and/or b) the default value on startup could also be customized. Is this possible?
      Typed on tiny plastic keys, just for you.
        The higher feed rates are for loading and unloading filament. But I rarely use feed rates other than 5 and 100mm/sec. So I agree that most of the available speeds are not useful. What would you like to see instead?
