    Duet Web Control 2.1.1 showing wrong job height
    Duet Web Control
    • olvrteilundefined
      olvrteil
      Hello all,
      Hope you're doing well in this special period.
      My DWC, is showing the same height for all my objects. I tried slicing with simplify 3d & Prusaslicer, result is the same.
      Do you have the same issue ?
      Have a nice day.
        Can you please try DWC 2.1.4 which just released.
        Also, which firmware?
        Can you share one of the gcode files as well?
        • olvrteilundefined
          olvrteil
          Hi Phaedrux,
          Here is my firmware :
          Board: Duet WiFi 1.02 or later (duetwifi102)
          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
          And i did the update for DWC :
          Duet Web Control 2.1.4
          Still have the same issue.
          Here is a gcode for exemple.
          Cadre ventilo.gcode
            I think I see the problem in your slicer end gcode
            G1 X10 Z75 F4800
            DWC is scanning the file for the last Z height found and is finding this from the end code. You can get it to ignore it by adding ; E to the end like so
            G1 X10 Z75 F4800 ; E
            This will make it think there is an extrusion value and will ignore it. That will likely solve the incorrect object height.
            • olvrteilundefined
              olvrteil
              Hi, perfect you find the problem.
              Your solution solves it.
              Thank for your help !
              Have a nice day
              • ToWi1989undefined ToWi1989 referenced this topic
