    What is the difference between the new G32 and G29?
    • djstephenson1undefined
      djstephenson1
      Hello all,
      I am curious what the actual difference between the G32 command and G29 command. I am running reprap firmware 3.0 on my Duet 2 Wifi.
      Any advice on this subject would be greatly appreciated. Thanks
      Jordan Stephenson, JD
        G29 is used to do mesh bed compensation.
        G32 is used to do the following:
        • Auto calibration on delta printers
        • True bed levelling on printers with multiple independent Z motors
        • The manual bed levelling assistant on machines with manual bed levelling screws
        • Old-style 3-, 4- and 5-point bed compensation, which is deprecated and likely to be removed soon.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
          https://duet3d.dozuki.com/Wiki/Gcode#Section_G32_Probe_Z_and_calculate_Z_plane
          https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
          https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
          https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed
          https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
