M117 missed, or scripts not completed.
  • I had this idea that I could hack the missing Z offset using tfree and tpost script, but it was not working as I wanted.
    So to debug it, I added M117 commands to the start and end of all four of them.
    But I don't get all the messages.
    A typical sequence of messages that I get is:
    tfree1
    tpost0
    tpost0 done
    tfree0
    tpost1
    tpost1 done
    tfree1
    tpost0
    tpost0 do…... etc.
    I never get the "tfree1 done" message. So either the M117 command is sluggish, or the scripts are not begin completed.
    Scripts here:
    tfree0.g:
    M117 "Free 0"
    M83  ; relative extruder movement
    G1 E-2 F3600  ; retract 2mm
    M82 ; absolute extruder movement
    G91  ; relative axis movement
    G1 Z3 F500  ; up 3mm
    G90  ; absolute axis movement
    G1 S2 X-27 F12000  ; park the X carriage at -27mm
    M117 "Free 0 done"
    G4 3000
    tfree1.g:
    M117 "Free 1"
    G1 Z35 F500  ; up 3mm
    G1 S2 U311.7 F12000  ; park the U carriage at +248mm
    M117 "Free 1 done"
    G4 3000
    tpost0.g:
    M117 "Post 0"
    M116 P0  ; wait for tool 0 heaters to reach operating temperature
    G1 E2 F3600  ; extrude 2mm
    G1 Z-3 F500  ; up 3mm
    M117 "Post0 done"
    G4 3000
    tpost1.g:
    M117 "Post 1"
    G1 Z-35 F500 ; up 3mm
    M117 "Post 1 done"
    G4 3000
    Ate you looking at the messages on DWC or on PanelDue? DWC stacks them up, but PanelDue doesn't have enough screen area for that so a new message will overwrite an old one.
  • Messages on DWC. Not all the messages are coming through.
    Kulitorum
    I have a feeling that messages may be skipped in the web interface if two or more are generated within the web interface polling interval. So try using G4 to insert a delay of half a second after each M117 command.
  • i did like dc42 says
    works good with a small pause
