    Fan speed during toolchange
    • danzaywerundefined
      danzaywer
      Hello everyone,
      I need help, is there a way to activate the tool fan 100% during the toolchange and bring it back to the value it had in the printing phase?
      I'm on firmware 3.01 RC9
      I could use objectmodels for something like
      ;in tfreeX.g
      M28 0:/sys/fan.g
      		M106 {object.fan.status}
      M29
      and then
      ;in TpostX.g
      m98 p "fan.g"
      any suggestions?
      • Danalundefined
        Danal
        It may be possible to do this without conditional g-code.
        Prior to invoking your tool change macros, the system does the equivalent of a "G60 S2". Therefore, you can do a M106 Px R2 (where x is the tool fan) to restore. This would go at the very end of tpostx.g
        Try this, I am not 100% sure it pushes the tool fan to the memory slot... but I seem to remember having done this with the print fan before.
        danzaywerundefined 1 Reply Last reply Reply Quote 1
          Try as @Danal suggested.
            danzaywer @Danal
            @Danal
            thanks! it worked perfectly.
